Home » Language IDEs » COBOL » cobol + oracle
cobol + oracle [message #469413] Tue, 12 December 2006 06:28 Go to next message
Eclipse User
Originally posted by: aventas.itdeusto.com
Hello.
I have running a project with cobol+db2 in websphere that is based on
eclipse.
It was easy: I opened a project of type COBOL after that I embedded the
sql instructions of DB2 and the only thing I must do is to include one
line in "project properties" --> "compilation options" --> "sql('database
BE user db2admin using admin DATETIME ISO')".
But now I have a project where I need to use ORACLE embedded in COBOL and
I canŽt be able to compile a program in COBOL with ORACLE. I try something
like DB2 but it doesnŽt work.
1.I fill the compilation option with the name of the oracle database and
it shows an error of precompilation as if it only search DB2 databases.
2. There is another option ("properties --> new connection") to stablish
connection to databases distinct to DB2 with jdbc, I declare the
"ojdbc14.jar" and the name of my database in oracle and websphere
recognize it and bring it into the project and I can see the contents of
the tables. It looks fine but I only see them in the view of "data" but I
canŽt access it by the program sentences. I must need some precompilation
option for Oracle that I donŽt know.
If someone can run COBOL with ORACLE in ECLIPSE I would appreciate some
help.
Thanks.
Re: cobol + oracle [message #782163 is a reply to message #469413] Mon, 23 January 2012 04:35 Go to previous messageGo to next message
Victor Wilson is currently offline Victor Wilson
Cobolclipse is the most advanced COBOL IDE using the Eclipse.
Re: cobol + oracle [message #1022570 is a reply to message #782163] Fri, 22 March 2013 02:33 Go to previous message
Jordan alon is currently offline Jordan alon
I was also having the same problem but yet to find the solution.
You can go with lawyer boca raton
Previous Topic:test
Next Topic:When implementing custom sequence, getGeneratedVector is executed twice in JTA environment
Current Time: Tue May 28 05:17:29 EDT 2013
Powered by FUDForum. Page generated in 0.01625 seconds
