Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Trouble using swt GLCanvas on linux(Trouble using swt GLCanvas on linux)
Trouble using swt GLCanvas on linux [message #1022304] Thu, 21 March 2013 12:37 Go to next message
Steven Reynolds is currently offline Steven Reynolds
I am having trouble using the swt GLCanvas while on linux. If I use the provided Snippet209
http://git.eclipse.org/c/platform/eclipse.platform.swt.git/tree/examples/org.eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet209.java
I get 100% CPU utilization. The code is clearly structured to cause this high utilitzation. It does (from the main method)
display.asyncExec(new Runnable() {
int rot = 0;
public void run() {
// draw stuff
display.asyncExec(this);
Which means that it busy loops drawing as fast as it can.
When I try to convert the snippet to draw on PaintEvents, the opengl drawing that I do is immediatedly klobbered with something that draws plain black.
Does anyone have any luck using the swt GLCanvas on linux? Busy looping won't work for my application, most of the time, the display should be static and not consume CPU.
I've attached the PaintEvent version as DemoSWT2.
thanks
Steven
Re: Trouble using swt GLCanvas on linux [message #1022372 is a reply to message #1022304] Thu, 21 March 2013 15:10 Go to previous message
Oh, I have a solution. It looks like the swt GLCanvas is doing GTK double buffering. The associated gtk buffer swap hammered my drawing. With the following change, the code seems fine now
retrieving revision 1.7
retrieving revision 1.8
diff -u -r1.7 -r1.8
--- DemoSWT2.java 20 Mar 2013 22:13:41 -0000 1.7
+++ DemoSWT2.java 21 Mar 2013 18:49:58 -0000 1.8
@@ -9,6 +9,7 @@
import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.events.PaintListener;
import org.eclipse.swt.graphics.Rectangle;
+import org.eclipse.swt.internal.gtk.OS;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.opengl.GLCanvas;
import org.eclipse.swt.opengl.GLData;
@@ -83,7 +84,11 @@
GLData data = new GLData ();
data.doubleBuffer = true;
final GLCanvas canvas = new GLCanvas(comp, SWT.NONE, data);
+ if (SWT.getPlatform().equals("gtk")) {
+ System.out.printf("Disabling GTK double buffering\n");
+ // TODO invoke reflectively?
+ OS.gtk_widget_set_double_buffered(canvas.handle,false);
canvas.setCurrent();
final GLContext context = GLDrawableFactory.getFactory().createExternalGLContext();
Previous Topic:Add Controls on Canvas at runtime
Next Topic:Weird problems resizing Shell with 'setBounds()'
Current Time: Wed May 22 02:32:09 EDT 2013
Powered by FUDForum. Page generated in 0.09833 seconds
