Home » Eclipse Projects » Buckminster » xtext P2 referencing specific version with P2 reader.
xtext P2 referencing specific version with P2 reader. [message #1015057] Wed, 27 February 2013 05:16 Go to next message
Christophe Bouhier is currently offline Christophe Bouhier
I am trying to import a specific version from the Xtext update site with
this .rmap entry:
<rm:searchPath name="org.eclipse.xtext">
<rm:provider componentTypes="buckminster,osgi.bundle,eclipse.feature"
readerType="p2" source="false" mutable="false">
<rm:property key="buckminster.source" value="false" />
<rm:property key="buckminster.mutable" value="false" />
<rm:uri
format="http://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases/{0}">
<bc:propertyRef key="xtext.version" />
</rm:uri>
</rm:provider>
</rm:searchPath>
Unfortunnately this doesn't work, as I can't simply concat the version
behind the uri fragment /releases/. How do I reference a specific
category in the p2 update site? I have tried with setting the
xtext.version to "TMF 20Xtext-2.0.1" with no success. (I can see this
category exists when trying the update site in the Eclipse IDE).
This is bucky's error:
ERROR [0019] : No suitable provider for component
org.eclipse.xtext:osgi.bundle was found in searchPath org.eclipse.xtext
ERROR [0019] : Rejecting provider
p2(http://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases/{0}[http://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases/TMF
Xtext-2.0.1]): No component match was found
ERROR No repository found at
http://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases/TMF%20Xtext-2.0.1/.
Thank You ! Christophe
Re: xtext P2 referencing specific version with P2 reader. [message #1015061 is a reply to message #1015057] Wed, 27 February 2013 05:38 Go to previous messageGo to next message
Lorenzo Bettini is currently offline Lorenzo Bettini
Although I've never done that myself, I think you should specify a
version range in the cquery...
On 02/27/2013 11:16 AM, Christophe Bouhier wrote:
> Hello,
> this .rmap entry:
> <rm:provider
> <rm:uri
> </rm:uri>
> </rm:provider>
> </rm:searchPath>
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
HOME: http://www.lorenzobettini.it
Re: xtext P2 referencing specific version with P2 reader. [message #1015067 is a reply to message #1015057] Wed, 27 February 2013 05:58 Go to previous messageGo to next message
Dennis Huebner is currently offline Dennis Huebner
You can't navigate through the composite repository by using an update site category label "TMF Xtext-2.0.1".
Xtext 2.0.1 repository is located here: http://download.eclipse.org/modeling/tmf/xtext/updates/releases/head/R201108020636/
If you would like to use the composite one, you have to use a version constraint in your cquery, like Lorenzo has suggested. Or put a version constraint in your feature. Buckminster will grab the right one.
+Dennis Hübner
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Re: xtext P2 referencing specific version with P2 reader. [message #1015071 is a reply to message #1015067] Wed, 27 February 2013 06:06 Go to previous messageGo to next message
Thanks! I just wonder where this URL is published on the web. I can't
find it in the Xtext download section here:
http://www.eclipse.org/modeling/tmf/downloads/?project=xtext
OK, will try this!
Re: xtext P2 referencing specific version with P2 reader. [message #1015096 is a reply to message #1015071] Wed, 27 February 2013 07:57 Go to previous messageGo to next message
I have been looking how, I can add a version constraint in a cquery, but
I don't see where and how this is done. Can someone please explain?
If it's done through an advisor node, which section should I use?
Is it the filter in the General section? If it's override, it seems this
is really to change the version in the materialized component right?
thank you, Christophe
> OK, will try this!
Re: xtext P2 referencing specific version with P2 reader. [message #1015097 is a reply to message #1015096] Wed, 27 February 2013 08:07 Go to previous messageGo to next message
Normally I use the constraints in my buckminster CSPEC
<cs:cspec xmlns:cs="http://www.eclipse.org/buckminster/CSpec-1.0" name="org.eclipse.xtext.releng" componentType="buckminster" version="1.0.0.qualifier">
    <cs:dependencies>
        <cs:dependency name="com.google.guava" componentType="osgi.bundle" versionDesignator="[10.0.0,12.0.0)"/>
Sometimes it's necessary to override version cotraint in the cquery:
    <cq:advisorNode namePattern="org.eclipse.emf.ecore.editor" componentType="osgi.bundle" useTargetPlatform="false" versionOverride="[2.5.0,2.6.0)"/>
+Dennis Hübner
Re: xtext P2 referencing specific version with P2 reader. [message #1015101 is a reply to message #1015097] Wed, 27 February 2013 08:20 Go to previous messageGo to next message
Thanks Dennis. Does it mean you create your own cspec? (As these would
be generated normally when using a feature containing all dependencies).
> <cs:dependencies>
Re: xtext P2 referencing specific version with P2 reader. [message #1015104 is a reply to message #1015101] Wed, 27 February 2013 08:26 Go to previous messageGo to next message
Yes, I have an own CSPEC for my releng project in order to set up the target platform first.
However, you can also use your "main/build" feature to define constraints e.g
   <requires>
      <import feature="org.eclipse.xtend.sdk" version="2.4.0" match="equivalent"/>
      <import plugin="org.eclipse.emf.ecore" version="2.5.0" match="greaterOrEqual"/>
      <import plugin="org.eclipse.emf.common" version="2.5.0" match="greaterOrEqual"/>
      <import plugin="org.eclipse.emf.ecore.source" version="2.5.0" match="greaterOrEqual"/>
      <import plugin="org.eclipse.emf.common.source" version="2.5.0" match="greaterOrEqual"/>
   </requires>
Buckminster will take care that this contraints are fulfilled.
+Dennis Hübner
Re: xtext P2 referencing specific version with P2 reader. [message #1015145 is a reply to message #1015104] Wed, 27 February 2013 10:12 Go to previous messageGo to next message
> constraints e.g
Tried this, unfortunately it still drags in the latest release of Xtext
(2.3.1).
Then I also tried with the cquery override, and the provider gets rejected.
ERROR [0022] : No suitable provider for component
org.eclipse.xtext:osgi.bundle/[2.0.0,2.0.1] was found in searchPath local
ERROR [0022] : Resolution attempt ended with exception: Provider
local(/var/lib/jenkins/workspace/netxstudio.git.p2/org.eclipse.xtext):
Missing CSpec source required by component type osgi.bundle
.....further on the provder rejection with the URL you gave me. (I
checked in Eclipse and it looks OK).
ERROR [0022] : Rejecting provider
p2(http://download.eclipse.org/modeling/tmf/xtext/updates/releases/head/R201108020636/[http://download.eclipse.org/modeling/tmf/xtext/updates/releases/head/R201108020636/]):
Here is my cquery definition:
<cq:advisorNode namePattern="^org\.eclipse\.xtext\.*"
componentType="osgi.bundle" versionOverride="[2.0.0,2.0.1]">
<cq:documentation xmlns="http://www.w3.org/1999/xhtml">Version
requirements on Xtext</cq:documentation>
</cq:advisorNode>
What am I doing wrong?
> <requires>
> </requires>
Re: xtext P2 referencing specific version with P2 reader. [message #1015160 is a reply to message #1015145] Wed, 27 February 2013 10:37 Go to previous messageGo to next message
Could you please post how your build feature looks like? And the rmap?
And the cquery pattern would only match bundles named org.eclipse.xtext(many dots)
Try this: <cq:advisorNode namePattern="^org\.eclipse\.xtext.*" versionOverride="[2.0.0,2.0.2)">
+Dennis Hübner
Re: xtext P2 referencing specific version with P2 reader. [message #1015191 is a reply to message #1015160] Wed, 27 February 2013 12:25 Go to previous messageGo to next message
I widened the version range, to 2.2.0 and it works now!
thanks. Christophe
Re: xtext P2 referencing specific version with P2 reader. [message #1015192 is a reply to message #1015191] Wed, 27 February 2013 12:31 Go to previous messageGo to next message
Buckminster just works Twisted Evil
+Dennis Hübner
Re: xtext P2 referencing specific version with P2 reader. [message #1022340 is a reply to message #1015104] Thu, 21 March 2013 13:46 Go to previous message
I'm resuming this thread for a similar question:
> constraints e.g
I tried to put in my main feature this
<requires>
<import feature="org.eclipse.xtext.sdk" version="2.3.1" match="equivalent"/>
</requires>
which should be equivalent to [2.3.1,2.4.0)
however, the materialization still drags in Xtext 2.4.0...
can it be because I also have a dependency on org.eclipse.xtext.sdk in
my main cspec (without any version designator)?
thanks in advance
Lorenzo
> <requires>
> </requires>
Previous Topic:Jenkins/Hudson -&gt; Buckminster plugin support.
Next Topic:ANN: Buckminster for Kepler
Current Time: Tue May 28 23:27:34 EDT 2013
Powered by FUDForum. Page generated in 0.02320 seconds
