Home » Language IDEs » Java Development Tools (JDT) » Eclipse, Web Service Client, WSDL, login and HTTPS(Generate code in Eclipse with a new Web Service Client, accessing to the WSDL logged as admin via HTTPS)
Eclipse, Web Service Client, WSDL, login and HTTPS [message #1022301] Thu, 21 March 2013 12:27
Yaguinho Vieiras is currently offline Yaguinho Vieiras
Hi all,
I want to generate code from a WSDL. I use the Eclipse wizard to create a new Web Service Client. In the wizard I indicate the URL of the WSDL file to be retrieved via HTTPS. The URL is like the following:
https:// instancename.subdomain.com/table_1.php?WSDL
But I obtain a WSDL file for guest users. Why? Because I am not logged into the instance so the system gives me a guest WSDL. I need to be logged as admin to retrieve an admin WSDL.
guest WSDL: 26 fields
admin WSDL: 30 fields
The difference is simple: with an admin access I can obtain four necessary fields from the table_1, used in the parameters and methods of the generated code. No admin, no well code generated.
The problem is that I do not know how to login as admin using Eclipse to retrieve the admin WSDL.
Thanks in advance,
Yago
_____________________________
Eclipse Juno Service Release 2
Libraries:
InstantClient/64v11203/ojdbc6.jar
org.apache.axis_1.4.0.v201005080400/lib/axis.jar
org.apache.commons.discovery_0.2.0.v201004190315/lib/commons-discovery-0.2.jar
javax.xml.rpc_1.1.0.v201005080400/lib/jaxrpc.jar
javax.xml.soap_1.2.0.v201005080501/lib/saaj.jar
javax.wsdl_1.6.2.v201012040545.jar
org.apache.commons.logging_1.0.4.v201101211617.jar
--- Yaguinho --
Previous Topic:bad contrast in context window
Next Topic:Can I use/share the same Workspace with a 32bit and a 64bit Eclipse?
Current Time: Sun May 19 18:46:30 EDT 2013
Powered by FUDForum. Page generated in 0.01480 seconds
