Home » Modeling » EMF » [XCore] derived feature unimplemented
[XCore] derived feature unimplemented [message #1022244] Thu, 21 March 2013 10:34 Go to next message
Martin  odloucký is currently offline Martin odloucký
Member
another problem with (the newest M6 milestone of) XCore. There are two xcore projects named 'base' and 'extender'. The 'base' project is generated from base.xcore:
package base
class Foo {}
class Bar {
	int x
	int y
	derived int sum get {
		return x + y
class MyClass extends Foo, Bar {}
the 'extender' depends on 'base' and is genreated from extender.xcore:
package extender
import base.Foo
import base.Bar
The result is that base.MyClassImpl is different than extender.MyClassImpl. The getSum() method from base.MyClassImpl is generated correctly. The same method in extender.MyClassImpl throws UnsupportedOperationException. Is it a bug or did I miss something? Both projects are attached in the ZIP file.
Re: [XCore] derived feature unimplemented [message #1022325 is a reply to message #1022244] Thu, 21 March 2013 13:09 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Martin,
That definitely sounds like a bug so given it's reproducible in M6---I
haven't the time to try because I'm preparing for EclipseCon---please
open a bugzilla. Of course you can change the order of the inheritance,
but your in real life code that might not be okay.
On 21/03/2013 3:34 PM, Martin odloucký wrote:
> package base
> class Foo {}
> class Bar {
> int x
> int y
> return x + y
> package extender
> import base.Foo
> import base.Bar
Re: [XCore] derived feature unimplemented [message #1023846 is a reply to message #1022325] Mon, 25 March 2013 05:46 Go to previous message
Member
Ok, the bug is here
https://bugs.eclipse.org/bugs/show_bug.cgi?id=404061
Previous Topic:[xcore] xcore Editor crashes with xText 2.4
Next Topic:How to generate "@since" tags in JDoc?
Current Time: Mon May 20 01:54:03 EDT 2013
Powered by FUDForum. Page generated in 0.02341 seconds
