Home » Language IDEs » PDT » Eclipse PDT in J2ee all in one(Get install errors when attepting PDT install in eclipse Juno j2ee all-in-one)
Eclipse PDT in J2ee all in one [message #1007406] Tue, 05 February 2013 13:38 Go to next message
Joe Lyons is currently offline Joe Lyons
I have read the how to install eclipse pdt in juno post. I exclude all options except bare PDT installnfrom the install but with repeated tries of this bare install I get the following...
An error occurred while collecting items to be installed session context was:(profile=epp.package.jee, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.dltk,4.0.0.201206120848
No repository found containing: osgi.bundle,org.eclipse.dltk.console,4.0.0.201206120848
No repository found containing: osgi.bundle,org.eclipse.dltk.console.ui,4.0.0.201206120848
This repeats itself for various repository versions. I have the juno j2ee all in one version. Eclipse Java EE IDE for Web Developers.
Version: Juno Service Release 1 Build id: 20121004-1855
Any help available. Thank you!
Re: Eclipse PDT in J2ee all in one [message #1008471 is a reply to message #1007406] Tue, 12 February 2013 10:57 Go to previous messageGo to next message
Dimitri Joukoff is currently offline Dimitri Joukoff
Hi Joe,
I have the same version of Eclipse and had the same problem you had. I used Google to find the missing files, then downloaded them into the /plugin folder inside my Eclipse setup. I restarted Eclipse each time until the problem went away.
Here is the link where I got all my missing files: "Ibiblio : The Public's Library and Digital Archive" => mirrors.ibiblio.org/eclipse/technology/dltk/updates-dev/4.0-stable/plugins/
Everything seems to be working fine now. Razz
Dimitri
Hmmm.... so many sites block useful functions until you've jumped whatever arbitrary hurdles are set before you!! Sad
Re: Eclipse PDT in J2ee all in one [message #1021824 is a reply to message #1008471] Wed, 20 March 2013 14:39 Go to previous message
Frozen Tomb is currently offline Frozen Tomb
This is how I managed to solve it on my machine. Not sure if it works for you. Install 'Dynamic Languages Toolki - Core Frameworks' from 'Install New Software' prior to installing PDT.
Previous Topic:Set CSS3 in Web Content Settings
Next Topic:Can't install pdt in Juno j2ee
Current Time: Tue May 28 06:51:35 EDT 2013
Powered by FUDForum. Page generated in 0.01433 seconds
