Home » Modeling » OCL » Complete OCL file used for GMF validation
Complete OCL file used for GMF validation [message #1021547] Wed, 20 March 2013 05:53 Go to next message
Cedric Moonen is currently offline Cedric Moonen
I have a complete OCL file which decorates my EMF model. I know would like this complete OCL file to be taken into account for validation of instances of my domain model created via a GMF editor (built on top of my domain model).
Is there a way to achieve this ? If yes, are there any tutorial about this ?
Cédric
Re: Complete OCL file used for GMF validation [message #1021558 is a reply to message #1021547] Wed, 20 March 2013 06:08 Go to previous messageGo to next message
If the GMF editor uses a stnadard EMF Validation approach, you may have
some success using the Load Complete OCL Resource menu action (Juno
onwards).
The Complete OCL tutorial in the OCL documentation describes it.
Ed Willink
On 20/03/2013 09:53, Cedric Moonen wrote:
> Hello,
> my domain model).
> this ?
> Cédric
Re: Complete OCL file used for GMF validation [message #1021573 is a reply to message #1021558] Wed, 20 March 2013 06:27 Go to previous messageGo to next message
Hi Ed,
Thanks for the reply.
onwards).
I don't know exactly how GMF handles that but as far as I know, it doesn't validate the model itself. OCL constraints that were added to the EMF model are validated correctly (with the custom messages and severity levels).
However, the "Load Complete OCL Resource" action doesn't appear when I right-click on the diagram.
In the documentation it is mentioned that:
Prior to the Juno release, this meant that Complete OCL was only usable in custom Java applications since no standard modeling applications would load the complementing document.
This means I guess that you have to load the OCL resource programmatically. Is there any tutorial about that ?
I would also prefer this approach, since this avoids users to have to do unnecessary actions in the GMF editor (they don't have to know that our OCL constraints are in a separate file).
Cédric
Re: Complete OCL file used for GMF validation [message #1021850 is a reply to message #1021573] Wed, 20 March 2013 15:41 Go to previous messageGo to next message
On 20/03/2013 10:27, Cedric Moonen wrote:
> Hi Ed,
> Quote:
>> have some success using the Load Complete OCL Resource menu action
>> (Juno onwards).
> severity levels).
That's encouraging.
There is a missing usage of IAdaptable to convert the GEF selection to
an EObject. Fix pushed on a GIT branch and building now.
An N-build should be available tomorrow.
> Quote:
There is some description in the OCL documentation. But you have to have
programmatic access.
Ed Willink
Re: Complete OCL file used for GMF validation [message #1022826 is a reply to message #1021850] Fri, 22 March 2013 11:49 Go to previous message
Ed,
I've been trying the nightly build and indeed I now have a "Load Complete OCL Resource" in my GMF editor and the validation works fine.
Thanks for the help.
Cédric
Previous Topic:[Complete OCL] Correct way of importing referred metamodels
Next Topic:OCL Constraint in ecore model
Current Time: Mon May 20 18:06:28 EDT 2013
Powered by FUDForum. Page generated in 0.05783 seconds
