| build error - .mtj.tmp\emulation (Access is denied) [message #988454] |
Thu, 29 November 2012 18:14  |
Sergey Smirnov Messages: 3 Registered: November 2012 |
Junior Member |
Few weeks ago, my project was packed without any problems.
After a small break in the work I encountered the problem can not be packed.
At the same time, in the directory ../.mtj.tmp/emulation/ exist the desired *.jar file.
Help me please. Internet did not give me an answer.
Below is a bug:
C:\Firmware\.mtj.tmp\emulation (Access is denied).
eclipse.buildId=M20120208-0800
java.version=1.7.0_09
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ru_RU
Command-line arguments: -os win32 -ws win32 -arch x86
java.io.FileNotFoundException: C:\Firmware\.mtj.tmp\emulation (Access is denied)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(Unknown Source)
at org.eclipse.mtj.internal.core.project.midp.ApplicationDescriptor.store(ApplicationDescriptor.java:661)
at org.eclipse.mtj.internal.core.packaging.midp.DeployedJADWriter.writeJad(DeployedJADWriter.java:153)
at org.eclipse.mtj.internal.core.packaging.midp.DeployedJADWriter.writeDeployedJAD(DeployedJADWriter.java:98)
at org.eclipse.mtj.internal.core.build.packaging.PackageBuilder.updatePackage(PackageBuilder.java:242)
at org.eclipse.mtj.internal.core.build.packaging.PackageBuilder.doBuild(PackageBuilder.java:107)
at org.eclipse.mtj.internal.core.build.MTJIncrementalProjectBuilder.build(MTJIncrementalProjectBuilder.java:70)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:256)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:394)
at org.eclipse.core.internal.resources.Project$1.run(Project.java:618)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.core.internal.resources.Project.internalBuild(Project.java:597)
at org.eclipse.core.internal.resources.Project.build(Project.java:114)
at org.eclipse.mtj.internal.ui.preferences.PreverificationPreferencePage$1.run(PreverificationPreferencePage.java:138)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
| Re: build error - .mtj.tmp\emulation (Access is denied) [message #1021317 is a reply to message #1019097] |
Tue, 19 March 2013 17:26  |
Junior Member |
Error occure when in .project file of project in section <buildCommand><name>org.eclipse.mtj.core.packageBuilder</name> add next strings:
<dictionary>
<key>_do_obfuscation</key>
<value>false</value>
</dictionary>
<dictionary>
<key>_do_package</key>
<value>true</value>
</dictionary>
<dictionary>
<key>_update_version</key>
<value>true</value>
</dictionary>
Anyone know what is the reason of this error?
[Updated on: Tue, 19 March 2013 17:26] Report message to a moderator
FUDForum. Page generated in 0.01720 seconds
