Jeni Martin Messages: 15 Registered: November 2012
I want to define a profile with two stereotypes (suppose C1, C2) that are the extension of metaclass Class. they both have the same attribute with the same type (suppose attribute1).
There is another stereotype which is the extension of dependency. and this dependency would be from C1 to C2.
I could define the client and supplier members of this dependency with OCL. but I cannot check when two classes of C1 and C2 are connected with this dependency, the value of their attribute for attribute1 must be the same.
It seems very unwise, and probably ill-formed, to have two same-named
attributes.
Wouldn't it be better to have C1 and C2 extend Cbase so that there was
only one attribute and that the attribute was inherently consistent?
Ed Willink
On 18/03/2013 20:17, Jeni Martin wrote:
> attribute with the same type (suppose attribute1). There is another
> be the same.
> I appriciate if anyone can help me.
> Thanks
Thank you so much for your reply.
But I want to have a constraint to say whenever this dependency is between this two classes, the value a specific attributes must be the same. to make it better, suppose the name of attributes are different.
> thank you so much
