| unresolved inclusions [message #1020724] |
Mon, 18 March 2013 16:09  |
sydney faria Messages: 17 Registered: March 2013 |
Junior Member |
I have a small C style coded project with the files in a C++ project that were imported from Eckels book code. At the beginning of the c library file and main c file there are several includes: <assert.h> ,<stdlib.h>, <string.h>, & <stdio.h> and the code is showing up "unresolved inclusion <library file>" messages. These includes are in both the library file and the main file. I've done the same thing in other projects so I don't see why I'm getting this message or even what this message means.
| Re: unresolved inclusions [message #1020987 is a reply to message #1020724] |
Tue, 19 March 2013 05:58   |
Nick Schweyer Messages: 151 Registered: July 2009 |
Quote:"unresolved inclusion <library file>"
This means that the library file could not be found.
You have to set the pathes in project/properties/C/C++ include pathes and symbols
Nick Schweyer
Eclipse Helios, Qt 4.3, Qt integration, open Suse Linux 11.3
| Re: unresolved inclusions [message #1021211 is a reply to message #1020987] |
Tue, 19 March 2013 13:10  |
Junior Member |
I have 10 projects created, all from the Eckel book, and this is the only project that shows this error about the include files not found. If I go into the Project/Properties/C/C++ Build menu and look at the environment I see CWD, PWD, & PATH variables set up and especially the PATH is set to C:/minGW/bin directory so it looks like the compiler/linker should find the library files! Also C/C++ General/Paths and Symbols/Languages/GNU C has C:/minGW/include in there and so does the Preprocessor Include Paths contain C:/mingw/include! So I think this is not the problem, but again I can't find a solution.
[Updated on: Tue, 19 March 2013 13:12] Report message to a moderator
FUDForum. Page generated in 0.01805 seconds
