Home » Eclipse Projects » Eclipse Platform » Adding PropertyPage to Project Resources(Trouble identifying projects in workspace.)
Adding PropertyPage to Project Resources [message #1016488] Wed, 06 March 2013 11:29 Go to next message
John VanAntwerp is currently offline John VanAntwerp
I am writing a plug-in that needs to have a new property page for all the projects int he workspace. All the documentation I can find says that you should look for resources implementing the IProject workspace and so I write my extension as:
<extension
         point="org.eclipse.ui.propertyPages">
      <page
            class="sf.icp.eclipse.plugins.myplugin.properties.MyPluginPropertyPage"
            id="sf.icp.eclipse.plugins.myplugin.properties.MyPluginPropertyPage"
            name="My Eclipse Plugin">
         <enabledWhen>
	            <instanceof
	                  value="org.eclipse.core.resources.IProject">
	            </instanceof>
         </enabledWhen>
      </page>
</extension>
However, it appears that Java projects (and Java-related projects) implement the org.eclipse.jdt.core.IJavaProject interface which is outside the IProject inheritance tree. I can get the property page to attach to Java projects (although not consistently for some reason) by changing the <enabledWhen> to:
         <enabledWhen>
         	<or>
	            <instanceof
	            </instanceof>
	            <instanceof
	                  value="org.eclipse.jdt.core.IJavaProject">
	            </instanceof>
            </or>
         </enabledWhen>
but there are still processing issues when I am assuming the resources are IProjects.
So I have some questions:
Is there a common ancestor for all project types that I can base my plug-in code on or do I have to check for and handle both project types separately?
Are IJavaProject and IProject the only two I need to worry about or are there others?
How is this usually handled? I've searched the forums and documentation for a couple of days and haven't found any answers.
Thanks!
- John
Re: Adding PropertyPage to Project Resources [message #1019765 is a reply to message #1016488] Sat, 16 March 2013 11:56 Go to previous message
Ed Merks is currently offline Ed Merks
John,
Being a Java project is more about being an IProject that has a Java
nature. There is no hierarchy for IProject that's meaningful, because
it's not intended to b subclass outside the resource framework's
implementation. I think there's some kind of has nature test you can do
in these expressions...
> <extension
> <page
> <enabledWhen>
> <instanceof
> </instanceof>
> </enabledWhen>
> </page>
> </extension>
> <enabledWhen>
> <or>
> <instanceof
> </instanceof>
> <instanceof
> </instanceof>
> </or>
> </enabledWhen>
> are IProjects.
> types separately?
> are there others?
> Thanks!
> - John
Previous Topic:Platform coverage for eclipse Juno SR2
Next Topic:Support for developing WinCE application by using Eclipse IDE
Current Time: Fri May 24 08:12:05 EDT 2013
Powered by FUDForum. Page generated in 0.01593 seconds
