Home » Modeling » UML2 » digram class problem
digram class problem [message #1019277] Fri, 15 March 2013 07:04 Go to next message
feres feres is currently offline feres feres
Hello everyone Smile
During my project study end I found a problem more precisely in class diagram
Here's the problem I have:
an electronic component belongs to one and only one category.
each category has specific properties that are different from other classes
you can find a property in several categories
each component has specific values ​​for these properties
I work for several days and whenever there is a problem. following two proposals that I worked on it
someone had had advice to give me thank you in advance
  • Attachment: class1.png
    (Size: 8.80KB, Downloaded 34 times)
  • Attachment: class2.png
    (Size: 12.28KB, Downloaded 27 times)
Re: digram class problem [message #1019380 is a reply to message #1019277] Fri, 15 March 2013 11:13 Go to previous messageGo to next message
Unfortunately your English makes your problem far from clear.
A 3-way AssociationClass is unlikely to be a good solution, particularly
not unless your an expert.
A 2-way AssociationClass is also unlikely to be a good solution.
"an electronic component belongs to one and only one category." suggests
composition but none is shown.
"each category has specific properties that are different from other
classes". This seems to be a confusion of terminology and/or
meta-levels. Uniqueness/difference is normally correct by careful design
of your class model, or enforced by OCL constraints later.
Ed Willink
On 15/03/2013 14:46, feres feres wrote:
> Hello everyone :)
icon4.gif  Re: digram class problem [message #1019397 is a reply to message #1019380] Fri, 15 March 2013 11:43 Go to previous messageGo to next message
Thank you for your cooperation Smile
So, I have to remove 3-way AssociationClass. and adding the composition in the other example.
Is that I am far from needs?
What thinks need to change in my work ? Rolling Eyes
    (Size: 13.22KB, Downloaded 27 times)
icon4.gif  Re: digram class problem [message #1019398 is a reply to message #1019380] Fri, 15 March 2013 11:44 Go to previous messageGo to next message
    (Size: 13.22KB, Downloaded 28 times)
Re: digram class problem [message #1019403 is a reply to message #1019398] Fri, 15 March 2013 11:53 Go to previous messageGo to next message
I don't understand your questions.
I don't understand :roll: - should I be rolling around with laughter?
I suggest you send in your assignment to your supervisor and see what
mark you get.
Please do not waste our time on your student work.
Ed Willink
On 15/03/2013 15:44, feres feres wrote:
> Thank you for your cooperation :)
> What thinks need to change in my work ? :roll:
icon14.gif  Re: digram class problem [message #1019408 is a reply to message #1019403] Fri, 15 March 2013 12:09 Go to previous message
Thank you for your comment Razz
Previous Topic:Anyone developing Professional Software using UML diagrams and Eclipse?
Next Topic:Referencing UML profiles and schemaLocation
Current Time: Tue May 28 17:37:48 EDT 2013
Powered by FUDForum. Page generated in 0.01550 seconds
