| Product customization not initialized (using extension) [message #1018813] |
Thu, 14 March 2013 10:17  |
B Richard Messages: 3 Registered: March 2013 |
Junior Member |
I'm working on building an Eclipse based IDE, which basically will take the main Eclipse plugins, and add a few of my own. I already developed some plugins, and they're working fine.
I also have a product defining plugin, which have a .product file. In this file, I specified the lauching product extension as "org.eclipse.platform.ide", and the application as "org.eclipse.ui.ide.workbench". I added my dependencies (i.e. my other plugins), and it works great.
However, I wanted to change the default perspective to a custom one I made, so I used the org.eclipse.core.runtime.products extension, and defined some product properties (the usual ones for this extension: preferenceCustomization, aboutText, etc.).
The problem is that those definitions aren't working. I have other extensions defined in this plugin that are working, but anything in the org.eclipse.core.runtime.products extension isn't "loading". The aboutText isn't the one I wrote, the windowsImages aren't the one I chose, the preferenceCustomization aren't the ones from my plugin_customization.ini, etc.
In my .product file, I tried to add the "-perspective myPerspectiveId" property to the configuration file, but this doesn't work either. As a matter of fact, when exporting the product, that property isn't even in the eclipse.ini file. Same goes when I tried to add the "-preferenceCustomization" property.
So I'm obviously doing something wrong, but I have no idea what. Anyone knows?
Thanks.
FUDForum. Page generated in 0.04383 seconds
