Home » Eclipse Projects » Plugin Development Environment (PDE) » Eclipse plugin for flow diagram(Eclipse plugin for flow diagram)
Eclipse plugin for flow diagram [message #1019349] Fri, 15 March 2013 09:57
justin Mising name is currently offline justin Mising name
1. The objective of plug-in is to construct a flow diagram with file names which will be available as icons in GUI window of eclipse.
2. flow will be formed by drag-drop of file icons using connectors. Green for success and red for error and target will be another file name icon.
Alternatively, data icon can be given- on right-click of this icon,list of file names(that is loaded from file) needs to be shown that can be selected.
3. It is required to generate XML file for this flow.
Is it possible using Eclipse plug-ins.
Appreciate if you could reply at earliest possible as iam doing feasibility of this usecase.
Previous Topic:New menu entry in Run As
Next Topic:Product customization not initialized (using extension)
Current Time: Thu May 23 14:39:05 EDT 2013
Powered by FUDForum. Page generated in 0.01666 seconds
