Home » Eclipse Projects » Rich Client Platform (RCP) » RCP closing view handle(RCP closing view handle)
RCP closing view handle [message #1019346] Fri, 15 March 2013 09:55 Go to next message
abc test is currently offline abc test
0 down vote favorite
In my Rcp application if user close a view all modified data not saved in to the project, inorder to avoid that implement ISavable part and override isSaveOnCloseNeeded() The pblm here is that it ask user any modification done while closing view.If click yes it sved modified data,but click no it again asking smeconfirmation window how avoid that my sample code like this public class ExplorerView extends CommonNavigator implements KeyListener, ISaveablePart, IProjectExplorerView {
public boolean isSaveOnCloseNeeded(){
if (true == isAnyProjectToSave()) {
MessageBox messageBox = new MessageBox(Display.getCurrent().getActiveShell(),
SWT.YES | SWT.NO
| SWT.ICON_WARNING);
messageBox.setText("Exit Explorer");
messageBox.setMessage("Do you want to save ]?");
int buttonID = messageBox.open();
if (SWT.YES == buttonID)
try
saveAll();
catch (Exception e)
e.printStackTrace();
if (SWT.NO == buttonID){
return false;
return false;
Re: RCP closing view handle [message #1021735 is a reply to message #1019346] Wed, 20 March 2013 11:41 Go to previous message
Wim Jongman is currently offline Wim Jongman
Hi abc,
Just implement ISaveablePart and flow with the framework.
Wim
> @Override
> SWT.YES | SWT.NO
> | SWT.ICON_WARNING);
> try
> saveAll();
> catch (Exception e)
> return false;
> return false;
Previous Topic:java.lang.RuntimeException: Application could not be found in the registry
Next Topic:how to change colour of label in swt tree editor
Current Time: Fri May 24 11:20:46 EDT 2013
Powered by FUDForum. Page generated in 0.01625 seconds
