Home » Eclipse Projects » Rich Client Platform (RCP) » Toolbar pulldown - item order(How to get defined order of fragment contributions)
Toolbar pulldown - item order [message #1019232] Fri, 15 March 2013 05:27 Go to next message
Torsten Harms is currently offline Torsten Harms
The elements in the MainToolbar of a Eclipse RCP application are made up declarative. When fragments are started, they contribute to the toolbar by adding a value to a pulldown, they add their portion also declarative.
But the order of the labels in the pulldown seems to be pure luck:
item1, item3, item2, item4, ...
Can I give them a predefined, fixed order? like "item1, item2, item3, item4"
To explain further more:
<!-- Main Plugin -->
<extension point="org.eclipse.ui.menus">
<toolbar id="de.example.mainToolbar">
  <command
    commandId="de.example.commands.item1"
    icon="item1.png"
    id="dropdowntoolbar.dropdown"
    label="%app.command.label.item1"
    style="pulldown"
    mode="FORCE_TEXT"
    tooltip="%app.command.tooltip.item1">
  </command>
</toolbar>
  <menuContribution
    locationURI="menu:dropdowntoolbar.dropdown"
  </menuContribution>
</extension>
each Fragment contributes to the command referencing via the menuContribution:
<!-- Fragment -->
<menuContribution locationURI="menu:dropdowntoolbar.dropdown">
  <command
    commandId="de.example.commands.item2"
    icon="item1.png"
    label="%app.command.label.item2"
    mode="FORCE_TEXT"
    style="push"
    tooltip="%app.command.label.tooltip.item2">
  </command>
</menuContribution>
I never finish anyth...
Re: Toolbar pulldown - item order [message #1021740 is a reply to message #1019232] Wed, 20 March 2013 11:50 Go to previous message
Wim Jongman is currently offline Wim Jongman
Hi Torsten,
I think that is caused by the order they are started and evaluated. I have no
solution. Maybe make the menu dynamic and add a listener to it that
reorganizes the entries?
In what order would you want them anyway? Alphabet? Is the order also
different between restarts?
Wim
item4"
> <command
> icon="item1.png"
> style="pulldown"
> mode="FORCE_TEXT"
> </command>
> </toolbar>
> <menuContribution
> </menuContribution>
> </extension>
menuContribution:
> <!-- Fragment -->
> <command
> icon="item1.png"
> mode="FORCE_TEXT"
> style="push"
> </command>
> </menuContribution>
Previous Topic:how to change colour of label in swt tree editor
Next Topic:Delete Saved Perspective
Current Time: Wed May 22 16:35:54 EDT 2013
Powered by FUDForum. Page generated in 0.01647 seconds
