| Table Snippet349 Drag and Drop visual problem [message #1019174] |
Fri, 15 March 2013 03:16  |
Jürgen Weinberger Messages: 26 Registered: August 2012 |
Junior Member |
Hello! I found this Table Snippet349 which describes my Problem pretty well. In the sample code a custom drawn table with different image sizes is described. I changed some things to describe my problem at work.
First i changed the Table to a Tree, this works pretty well with different sizes of the images. Second I added a simple Drag and Drop Support and this is where the trouble starts. When i try to drag an element especially one with a wider image the text of the item gets cut of. It seems that the wider the image the more of the text gets cut of. (See the screenshots).
For me it looks like that the DnD is not using the Paint/Mesaure/Erase Events and instead calulates the size based on the TreeItem which is not correct.
Is there a way to get rid of this problem.
regards weinma
package test;
* Copyright (c) 2000, 2010 IBM Corporation and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* IBM Corporation - initial API and implementation
* Table example snippet: Show a Table with images of various sizes
* For more info on custom-drawing TableItem and TreeItem content see
* http://www.eclipse.org/articles/article.php?file=Article-CustomDrawingTableAndTreeItems/index.html
* For a list of all SWT example snippets see
* http://www.eclipse.org/swt/snippets/
* @since 3.2
import org.eclipse.jface.viewers.TreeViewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.dnd.DND;
import org.eclipse.swt.dnd.DragSourceEvent;
import org.eclipse.swt.dnd.DragSourceListener;
import org.eclipse.swt.dnd.TextTransfer;
import org.eclipse.swt.dnd.Transfer;
import org.eclipse.swt.graphics.FontMetrics;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.TableItem;
import org.eclipse.swt.widgets.Tree;
import org.eclipse.swt.widgets.TreeColumn;
import org.eclipse.swt.widgets.TreeItem;
public class TableMain {
public static void main(String [] args) {
final int COLUMN_COUNT = 1;
final int TEXT_MARGIN = 3;
final String KEY_WIDTHS = "widths";
final String KEY_IMAGES = "images";
Display display = new Display();
Image[] images = new Image[4];
images[0] = createImage(display, 16, 16);
images[1] = createImage(display, 32, 16);
images[2] = createImage(display, 48, 16);
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
Tree tree = new Tree(shell, SWT.NONE);
for (int i = 0; i < COLUMN_COUNT; i++) {
new TreeColumn(tree, SWT.NONE);
for (int i = 0; i < 8; i++) {
TreeItem item = new TreeItem(tree, SWT.NONE);
Image[] itemImages = new Image[COLUMN_COUNT];
item.setData(KEY_IMAGES, itemImages);
for (int j = 0; j < COLUMN_COUNT; j++) {
item.setText(j, "item " + i + " col " + j);
itemImages[j] = images[(i * COLUMN_COUNT + j) % images.length];
* NOTE: MeasureItem, PaintItem and EraseItem are called repeatedly.
* Therefore, it is critical for performance that these methods be
* as efficient as possible.
final int itemHeight = tree.getItemHeight();
GC gc = new GC(tree);
FontMetrics metrics = gc.getFontMetrics();
final int fontHeight = metrics.getHeight();
gc.dispose();
Listener paintListener = new Listener() {
public void handleEvent(Event event) {
switch (event.type) {
case SWT.MeasureItem: {
int column = event.index;
TreeItem item = (TreeItem)event.item;
Image[] images = (Image[])item.getData(KEY_IMAGES);
Image image = images[column];
if (image == null) {
/* don't change the native-calculated event.width */
break;
int[] cachedWidths = (int[])item.getData(KEY_WIDTHS);
if (cachedWidths == null) {
cachedWidths = new int[COLUMN_COUNT];
item.setData(KEY_WIDTHS, cachedWidths);
if (cachedWidths[column] == 0) {
int width = image.getBounds().width + 2 * TEXT_MARGIN;
GC gc = new GC(item.getParent());
width += gc.stringExtent(item.getText()).x;
gc.dispose();
cachedWidths[column] = width;
event.width = cachedWidths[column];
break;
case SWT.EraseItem: {
break;
/* disable the native drawing of this item */
event.detail &= ~SWT.FOREGROUND;
break;
case SWT.PaintItem: {
/* this item is drawn natively, don't touch it*/
break;
int x = event.x;
event.gc.drawImage(image, x, event.y + (itemHeight - image.getBounds().height) / 2);
x += image.getBounds().width + TEXT_MARGIN;
event.gc.drawString(item.getText(column), x, event.y + (itemHeight - fontHeight) / 2);
break;
tree.addListener(SWT.MeasureItem, paintListener);
tree.addListener(SWT.EraseItem, paintListener);
tree.addListener(SWT.PaintItem, paintListener);
TreeViewer viewer = new TreeViewer(tree);
viewer.addDragSupport(DND.DROP_COPY | DND.DROP_MOVE, new Transfer[]{TextTransfer.getInstance()}, new DragSourceListener() {
public void dragStart(DragSourceEvent event) {
// TODO Auto-generated method stub
public void dragSetData(DragSourceEvent event) {
public void dragFinished(DragSourceEvent event) {
tree.getColumn(i).pack();
shell.pack();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
for (int i = 0; i < images.length; i++) {
if (images[i] != null) {
images[i].dispose();
display.dispose();
static Image createImage(Display display, int width, int height) {
Image result = new Image(display, width, height);
GC gc = new GC(result);
for (int x = -height; x < width; x += 4) {
gc.drawLine(x, 0, x + height, height);
gc.dispose();
return result;
FUDForum. Page generated in 0.01570 seconds
