| RAP File downloading [message #1016177] |
Tue, 05 March 2013 06:05  |
Markus Duft Messages: 44 Registered: February 2013 |
Member |
Hey. Me again
In our application i want to send a download to the client. The file is generated on the fly and sent to the client. So far everything works like a charm with this code:
public boolean sendDownload(byte[] data, String filename) {
DownloadService service = new DownloadService(data, filename);
service.register();
UrlLauncher launcher = RWT.getClient().getService(UrlLauncher.class);
launcher.openURL(service.getURL());
return true;
private static final class DownloadService implements ServiceHandler {
private final byte[] data;
private final String filename;
private String id;
public DownloadService(byte[] data, String filename) {
this.data = data;
this.filename = filename;
this.id = calculateId();
public String getURL() {
return RWT.getServiceManager().getServiceHandlerUrl(getId());
private String getId() {
return id;
private String calculateId() {
return String.valueOf(System.currentTimeMillis()) + data.length;
public boolean register() {
try {
RWT.getServiceManager().registerServiceHandler(getId(), this);
return true;
} catch (Exception e) {
log.error("failed to register download service handler", e);
return false;
private boolean unregister() {
try {
RWT.getServiceManager().unregisterServiceHandler(getId());
return true;
log.error("failed to unregister download service handler", e);
return false;
public void service(HttpServletRequest request, HttpServletResponse response)
throws IOException, ServletException {
try {
response.setContentType("application/octet-stream");
response.setContentLength(data.length);
response.setHeader("Content-Disposition", "attachment; filename=\"" + filename
response.getOutputStream().write(data);
log.error("failed to dispatch download");
} finally {
unregister();
the problem i have with this solution is, that it will open a separate browser window, and leave it open (at least with chrome), after the download was sent. is there a way to
1) close the browser window again?
2) don't open a browser window at all, but send the download in the main window (without destroying the running application )?
Thanks!
| Re: RAP File downloading [message #1018844 is a reply to message #1016177] |
Thu, 14 March 2013 11:01  |
Tim Buschtoens Messages: 246 Registered: July 2009 |
Hi.
We are aware of the issue. It was discussed, but no full solution could
be implemented for 2.0. I suggest you open an enhancement request for a
RAP downloader service on Bugzilla. As a workaround you could use the
JavaScriptExecuter to render something like "window.location = myURL".
Greetings,
Tim
Am 05.03.2013 12:05, schrieb Markus Duft:
> Hey. Me again :)
> service.register();
> return true;
> private String id;
> this.data = data;
> return id;
> data.length;
> try {
> this);
> return true;
> e);
> return false;
> try {
> return true;
> handler", e);
> return false;
> @Override
> try {
> } finally {
> unregister();
> window (without destroying the running application :))?
> Thanks!
Tim Buschtöns
Twitter: @EclipseRAP
FUDForum. Page generated in 0.01485 seconds
