| JMeter RAP/LoadTesting on RAP 1.5.0 Problem [message #1018307] |
Wed, 13 March 2013 11:39  |
Marcus Kalthoff Messages: 5 Registered: October 2011 |
Junior Member |
I tried to use jmeter according to http://wiki.eclipse.org/RAP/LoadTesting
. When I replay, after some correct repsones, I get "Multiple browser-instances" responses. What seems strange to me, is that the ${request_counter} placeholder occurs more then once. For example
?nocache=${request_counter}363${request_counter}796430${request_counter}3
?nocache=${request_counter}363${request_counter}79648529
?nocache=${request_counter}363${request_counter}796492${request_counter}6
?nocache=${request_counter}363${request_counter}79650${request_counter}85
Does anybody have an idea, what I am doing wrong?
Marcus
[Updated on: Wed, 13 March 2013 11:39] Report message to a moderator
| Re: JMeter RAP/LoadTesting on RAP 1.5.0 Problem [message #1018693 is a reply to message #1018680] |
Thu, 14 March 2013 06:16   |
Junior Member |
The stacktrace on the server is
00000028 servlet E com.ibm.ws.webcontainer.servlet.ServletWrapper service SRVE0068E: Es wurde eine Ausnahme von einer der Servicemethoden des Servlets in der Anwendung [ ] ausgelöst. Erstellte Ausnahme: [java.lang.ClassCastException: org.eclipse.swt.widgets.CoolItem incompatible with org.eclipse.swt.widgets.Control
at org.eclipse.swt.internal.widgets.shellkit.ShellLCA.setActiveControl(ShellLCA.java:240)
at org.eclipse.swt.internal.widgets.shellkit.ShellLCA.processActivate(ShellLCA.java:218)
at org.eclipse.swt.internal.widgets.shellkit.ShellLCA.readData(ShellLCA.java:94)
at org.eclipse.swt.internal.widgets.displaykit.DisplayLCA$1.doVisit(DisplayLCA.java:113)
at org.eclipse.swt.internal.widgets.WidgetTreeVisitor$AllWidgetTreeVisitor.visit(WidgetTreeVisitor.java:35)
at org.eclipse.swt.internal.widgets.WidgetTreeVisitor.accept(WidgetTreeVisitor.java:47)
at org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.readData(DisplayLCA.java:120)
at org.eclipse.rwt.internal.lifecycle.ReadData.execute(ReadData.java:26)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.continueLifeCycle(RWTLifeCycle.java:158)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.sleep(RWTLifeCycle.java:235)
at org.eclipse.swt.widgets.Display.sleep(Display.java:1176)
at org.eclipse.ui.application.WorkbenchAdvisor.eventLoopIdle(WorkbenchAdvisor.java:361)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2734)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2694)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2530)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:702)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:685)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
at de.cenit.ecliso.ui.workbench.internal.Application.start(Application.java:115)
at org.eclipse.rap.ui.internal.application.EntryPointApplicationWrapper.createUI(EntryPointApplicationWrapper.java:38)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:177)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:289)
at java.lang.Thread.run(Thread.java:769)
at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.java:102)
[Updated on: Thu, 14 March 2013 06:17] Report message to a moderator
| Re: JMeter RAP/LoadTesting on RAP 1.5.0 Problem [message #1018704 is a reply to message #1018680] |
Thu, 14 March 2013 06:32  |
This is a clear indication that the recorded widget ids don't match the
widget ids at runtime. Either you recorded the session with a slightly
different version of your application that the one used for replay, or
you've hit a problem with the text size determination.
The text size determination is a subsystem that can consume an
additional id in the first session, leading to different ids for all
subsequent widgets. You should be able to workaround this by following
these steps:
* Start the server
* Click though the session once without actually recording
(this initializes the text size determination store on the server)
* Remove session cookie or restart browser
(this ensures that your request counter starts at 0)
* Start recording
We plan to make the widget ids more stable in future versions to avoid
this kind of problems.
You don't have to exclude images, but you can because they don#t affect
the UI session.
Ralf
Ralf Sternberg
Twitter: @EclipseRAP
FUDForum. Page generated in 0.01791 seconds
