Home » Modeling » Graphiti » The location isn't set for DoubleClickFeatures
The location isn't set for DoubleClickFeatures [message #1018463] Wed, 13 March 2013 17:38 Go to next message
Hallvard Traetteberg is currently offline Hallvard Traetteberg
I guess the titles says it all: A DoubleClickFeature receives a
DoubleClickContext object with x and y fields, but these are not set to
where the user clicked. The fix to the performRequest method in
ShapeEditPart and ConnectionEditpart is trivial:
if (request instanceof LocationRequest) {
Point location = ((LocationRequest) request).getLocation();
dcc.setLocation(location.x, location.y);
I have added the following ticket:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=403272
Hallvard
Re: The location isn't set for DoubleClickFeatures [message #1020622 is a reply to message #1018463] Mon, 18 March 2013 11:25 Go to previous message
Michael Wenz is currently offline Michael Wenz
Hallvard,
thanks for pointing this out and also providing the solution.
Could you please add that coding to the bug? Reason is that we need every
code contribution (even such small ones) correctly marked for IP reasons and
this is only possible either by Gerrit and Bugzilla.
Michael
Previous Topic:Loading an existing model to a Graphiti Editor
Next Topic:Manhatten Connection overlaid
Current Time: Sat May 18 07:45:30 EDT 2013
Powered by FUDForum. Page generated in 0.01601 seconds
