Home » Newcomers » Newcomers » Error msg: No command output when running(I might have done some configuration changes in Eclipse ...)
Error msg: No command output when running [message #637820] Mon, 08 November 2010 21:50 Go to next message
Curtis Chou is currently offline Curtis Chou
and ever since I got this error msg for every application created, uploaded and ran on the emulator. However, all applications ran well on the emulator. Any ideas what's the cause & how to fix it?
Severity: Error
Message: No command output when running: 'am start -n curtis.tetrahedra.bouncing.ii/curtis.tetrahedra.bouncing.ii. CurtisII -a android.intent.action.MAIN -c android.intent.category.LAUNCHER' on device emulator-5554
Exception Stack Trace:
com.android.ddmlib.ShellCommandUnresponsiveException
at com.android.ddmlib.AdbHelper.executeRemoteCommand(AdbHelper. java:408)
at com.android.ddmlib.Device.executeShellCommand(Device.java:27 7)
at com.android.ide.eclipse.adt.internal.launch.ActivityLaunchAc tion.doLaunchAction(Unknown Source)
at com.android.ide.eclipse.adt.internal.launch.AndroidLaunchCon troller.launchApp(Unknown Source)
at com.android.ide.eclipse.adt.internal.launch.AndroidLaunchCon troller.simpleLaunch(Unknown Source)
at com.android.ide.eclipse.adt.internal.launch.AndroidLaunchCon troller.access$3(Unknown Source)
at com.android.ide.eclipse.adt.internal.launch.AndroidLaunchCon troller$3.run(Unknown Source)
Session Data:
eclipse.buildId=M20100909-0800
java.version=1.6.0_22
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_TW
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.java.product
Re: Error msg: No command output when running [message #637821 is a reply to message #637820] Mon, 08 November 2010 21:55 Go to previous messageGo to next message
Russell Bateman is currently offline Russell Bateman
>[snip]
stackOverflow is a good forum for this sort of thing.
Re: Error msg: No command output when running [message #1018179 is a reply to message #637820] Wed, 13 March 2013 06:20 Go to previous messageGo to next message
Marta Ribeiro is currently offline Marta Ribeiro
Hi. I'm having the same exact problem. Please tell me you solved and how, it's driving me crazy.
Thank you in advance.
Re: Error msg: No command output when running [message #1049358 is a reply to message #1018179] Thu, 25 April 2013 14:54 Go to previous message
M V is currently offline M V
I too have gone crazy with this problem...
Finally solved it with a simple configuration on Eclipse:
- Window --> Preferences
- Select Android -> DDMS from left panel
- Increase value of "ADB connection time out (ms)"
Previous Topic:Install Help
Next Topic:modules don't get loaded into interactive-shell [SOLVED]
Current Time: Fri May 24 15:03:44 EDT 2013
Powered by FUDForum. Page generated in 0.01716 seconds
