Home » Modeling » UML2 » Create Papyrus Project From UML file Using Java
Create Papyrus Project From UML file Using Java [message #1017824] Tue, 12 March 2013 11:52 Go to next message
edipo federle is currently offline edipo federle
Hello, I Have a question about if is possible through a .UML file ( a model ) generate a .notaion and .di files ( Papyrus Project).
I need a good way to visualize models, (.uml files) in Papyrus.
As I have several models, I can not generate it manually. Does anyone have any idea.?
Thanks a lot.
[]s
Re: Create Papyrus Project From UML file Using Java [message #1017832 is a reply to message #1017824] Tue, 12 March 2013 12:04 Go to previous message
Christian W. Damus is currently offline Christian W. Damus
This post was answered on the Papyrus forum. And, if you must post a
question to multiple fora, please cross-post. Don't spam the fora with
separate posts.
Christian
> have any idea.?
> Thanks a lot.
> []s
Previous Topic:Problem loading a UML model with a profile applied
Next Topic:Obtaining a value of a property defined in a profile
Current Time: Tue May 28 17:39:50 EDT 2013
Powered by FUDForum. Page generated in 0.03212 seconds
