| [EMF Compare] Comparing unordered elements [message #1017335] |
Mon, 11 March 2013 11:59  |
Olivier Mising name Messages: 14 Registered: May 2011 |
Junior Member |
I am starting to experiment with EMF Compare 2.1.
I tried to compare two simple identical models, having simply modified the order of some elements.
The elements are matched, however the result contains differences of the kind "MOVE".
I've checked the metamodel, to ensure that the corresponding EReference has its ordered property set to "false" and it is the case.
With EMF Compare 1.2 I did not have this problem.
Is there something I have forgotten to do to consider the order of the elements only when the EReference is ordered ?
In advance, thanks
FUDForum. Page generated in 0.08655 seconds
