Home » Modeling » TMF (Xtext) » How to avoid including ecore for dsl and load dynamically using Namespace uri of the ecore ?
How to avoid including ecore for dsl and load dynamically using Namespace uri of the ecore ? [message #1017197] Mon, 11 March 2013 00:15 Go to next message
Sri MV is currently offline Sri MV
I am new to xtext and trying to explore xtext . I have included my grammar and scope provider thanks to christian , Everytime i need to explicitly include my ecore within the project . Is there way in which i could load the ecore Eclass contents dynamically using Name spcae uri of the ecore.
Model:
	"EClass:" theEClass=[ecore::EClass|FQN] "Feature:" theFeature=[ecore::EStructuralFeature];
FQN: ID("." ID)*;
public class MyDslscopeProvider extends AbstractDeclarativescopeProvider {
	public Iscope scope_Model_theFeature(Model model, EReference ref) {
		return scopes.scopeFor(model.getTheEClass().getEAllStructuralFeatures());
For the above grammar text dsl project will look similar like this
 TestProject
    |- my.dsl
    |- sample.ecore
Everytime i need to include sample.ecore to show up classes in my project .. Is there way i could dynamically load and avoid adding sample.ecore everytime.
Sri
[Updated on: Mon, 11 March 2013 00:16]
Report message to a moderator
Re: How to avoid including ecore for dsl and load dynamically using Namespace uri of the ecore ? [message #1017209 is a reply to message #1017197] Mon, 11 March 2013 03:09 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian Dietrich
Hi I guess some basic reading on ecore could help. There is a
EPackage.Registry (but of course the package has to be registered
there. But same as in the other thread. I don't know your usecase so
hard to say anything
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: How to avoid including ecore for dsl and load dynamically using Namespace uri of the ecore ? [message #1017215 is a reply to message #1017209] Mon, 11 March 2013 04:19 Go to previous messageGo to next message
Hi Christian ,
My use case is very simple .
I am trying to create a simple editor for configuring a name rule which is a String made of EClass and EStructural feature of the ecore . I will not be generating any Java code from my grammar.
Does xtext provide content assist support for external ecore where i can get the EClass name and EStructural name for my name rule configuration.
Please refer the below model
http://i.stack.imgur.com/Qz4td.png
Simple content assist for Apple.name as my rule configurator
Sri M.V
[Updated on: Mon, 11 March 2013 04:21]
Re: How to avoid including ecore for dsl and load dynamically using Namespace uri of the ecore ? [message #1017241 is a reply to message #1017215] Mon, 11 March 2013 05:39 Go to previous messageGo to next message
what xtext does when you drop the ecore: the ecore is read as model und put into the Xtext index and thus is
referenceable from the .mydsl file.
SO if you dont want to drop the .ecore file what is the criteria to find it?
when is the ecore file created. and how should it be updated?
where should xtext look for it?
btw i was talking about the java code for the ecore.
Re: How to avoid including ecore for dsl and load dynamically using Namespace uri of the ecore ? [message #1017249 is a reply to message #1017241] Mon, 11 March 2013 06:01 Go to previous messageGo to next message
Hi Christian ,
Ecore would be part of my target . Is there a way where i can get from the target and Xtext index the target ecore .
Sri M.V
Re: How to avoid including ecore for dsl and load dynamically using Namespace uri of the ecore ? [message #1017250 is a reply to message #1017249] Mon, 11 March 2013 06:10 Go to previous message
Only if the Model project is a java Project.
Or you do the scoping yourself
(load the ecore reflective or via its java package)
=> write a scope method for the class too (scope_Model_theEClass)
Previous Topic:importURI and cross references during serialization
Next Topic:dependency injection in Xtext source code
Current Time: Sat May 25 06:37:20 EDT 2013
Powered by FUDForum. Page generated in 0.01839 seconds
