Home » Eclipse Projects » DSDP - Target Management » Cannot Transfer Files
Cannot Transfer Files [message #481150] Wed, 19 August 2009 15:05 Go to next message
Michael Yara is currently offline Michael Yara
I use RSE to manage files on my remote system. Recently I have been
unable to transfer files from my workstation to any of my systems using
RSE. When I transfer a file I see the progress indicator refreshing the
folder but the file never gets transfered and no errors are thrown or
logged. I have tried uninstalling and reinstalling TM and have even
tried a fresh install of eclipse 3.5 with TM3.1 and it still fails to
transfer. This was working before. I have tried on several different
servers but with no luck. Please help.
Mike
Re: Cannot Transfer Files [message #481368 is a reply to message #481150] Thu, 20 August 2009 12:19 Go to previous messageGo to next message
David McKnight is currently offline David McKnight
Hi Mike,
Which client are you on (i.e. windows, linux, etc.)? Could you describe how
you do the transfers? Is this via copy/paste from the "Local" system to a
remote system?
Dave
"Michael Yara" <michaely@i9technologies.com> wrote in message
news:h6hiek$t6u$1@build.eclipse.org...
> Hello,
> I use RSE to manage files on my remote system. Recently I have been unable
> to transfer files from my workstation to any of my systems using RSE. When
> I transfer a file I see the progress indicator refreshing the folder but
> the file never gets transfered and no errors are thrown or logged. I have
> tried uninstalling and reinstalling TM and have even tried a fresh install
> of eclipse 3.5 with TM3.1 and it still fails to transfer. This was working
> before. I have tried on several different servers but with no luck. Please
> help.
> Mike
Re: Cannot Transfer Files [message #482771 is a reply to message #481368] Thu, 27 August 2009 17:42 Go to previous messageGo to next message
This is a windows system and I transfer using copy/paste and/or drag and
drop. I cannot transfer files from my local system to a remote system or
from remote to remote. If i go from local to remote the previously
described behavior occurs. If i do a remote to remote i get this error.
Message reported from file system: java.io.FileNotFoundException:
C:\Documents and
Settings\Mike\XXX\Workspaces\XXXXXXXXX\RemoteSystemsTempFile s\PHONE.XXXXXXXXXX.COM\root\old\encode_template.xml
(The system cannot find the path specified)
Xs masking sensitive data.
David McKnight wrote:
> Hi Mike,
> remote system?
> Dave
>> Hello,
>> help.
>> Thanks,
>> Mike
Re: Cannot Transfer Files [message #482781 is a reply to message #482771] Thu, 27 August 2009 19:02 Go to previous messageGo to next message
I just tried on a fresh install of Eclipse 3.5 with TM 3.1 pulled from
the update site, new workspace and still shows the same behavior.
> C:\Documents and
>> Hi Mike,
>> describe how you do the transfers? Is this via copy/paste from the
>> "Local" system to a remote system?
>> Thanks,
>> Dave
>>> Hello,
>>> using RSE. When I transfer a file I see the progress indicator
>>> refreshing the folder but the file never gets transfered and no
>>> errors are thrown or logged. I have tried uninstalling and
>>> reinstalling TM and have even tried a fresh install of eclipse 3.5
>>> with TM3.1 and it still fails to transfer. This was working before. I
>>> have tried on several different servers but with no luck. Please help.
>>> Thanks,
>>> Mike
Re: Cannot Transfer Files [message #483175 is a reply to message #482781] Mon, 31 August 2009 09:21 Go to previous messageGo to next message
Hi Michael,
It's possible that the problem is the file path is too long for Windows
(there are path restrictions). Could you try this using a workspace with a
shorter path? For example, instead of using this:
C:\Documents and Settings\Mike\XXX\Workspaces\XXXXXXXXX\
could you try somethign like this:
C:\Workspace\
Dave
news:h7739t$7fv$1@build.eclipse.org...
>I just tried on a fresh install of Eclipse 3.5 with TM 3.1 pulled from the
>> C:\Documents and
>>> Hi Mike,
>>> how you do the transfers? Is this via copy/paste from the "Local"
>>> Thanks,
>>> Dave
>>>> Hello,
>>>> Thanks,
>>>> Mike
Re: Cannot Transfer Files [message #484892 is a reply to message #483175] Wed, 09 September 2009 11:50 Go to previous messageGo to next message
David,
Unfortunately your suggestion did not work. I thought for sure this was
the issue since I am seeing it occur even on a fresh install with a
brand new workspace.
Mike
> Hi Michael,
> C:\Workspace\
> Dave
>>> C:\Documents and
>>>> Hi Mike,
>>>> Thanks,
>>>> Dave
>>>>> Hello,
>>>>> Thanks,
>>>>> Mike
Re: Cannot Transfer Files [message #582192 is a reply to message #481150] Thu, 20 August 2009 12:19 Go to previous messageGo to next message
Hi Mike,
remote system?
Dave
> Hello,
> help.
> Mike
Re: Cannot Transfer Files [message #582337 is a reply to message #481368] Thu, 27 August 2009 17:42 Go to previous messageGo to next message
C:\Documents and
> Hi Mike,
> remote system?
> Dave
>> Hello,
>> help.
>> Thanks,
>> Mike
Re: Cannot Transfer Files [message #582352 is a reply to message #482771] Thu, 27 August 2009 19:02 Go to previous messageGo to next message
> C:\Documents and
>> Hi Mike,
>> Thanks,
>> Dave
>>> Hello,
>>> Thanks,
>>> Mike
Re: Cannot Transfer Files [message #582374 is a reply to message #482781] Mon, 31 August 2009 09:21 Go to previous messageGo to next message
Hi Michael,
C:\Workspace\
Dave
>> C:\Documents and
>>> Hi Mike,
>>> Thanks,
>>> Dave
>>>> Hello,
>>>> Thanks,
>>>> Mike
Re: Cannot Transfer Files [message #582469 is a reply to message #483175] Wed, 09 September 2009 11:50 Go to previous messageGo to next message
David,
Mike
> Hi Michael,
> C:\Workspace\
> Dave
>>> C:\Documents and
>>>> Hi Mike,
>>>> Thanks,
>>>> Dave
>>>>> Hello,
>>>>> Thanks,
>>>>> Mike
Re: Cannot Transfer Files [message #1017200 is a reply to message #484892] Mon, 11 March 2013 01:52 Go to previous message
Frank Zabelli is currently offline Frank Zabelli
Check out Long Path Tool. It is indeed very useful in this type of situation. It will help you solve your problems, it help me I have same problem.
Previous Topic:Could RSE be used to mirror local project to remote system
Next Topic:RSE Export / Import All Connections
Current Time: Wed May 29 03:34:39 EDT 2013
Powered by FUDForum. Page generated in 0.01843 seconds
