| Cannot Debug CDO Source [message #1017123] |
Sat, 09 March 2013 10:50  |
UmaShankar Subramani Messages: 76 Registered: December 2011 Location: SWEDEN |
Member |
When I am debugging CDO Source, most of the time I have to restart the debug again. Because of TimeOut. The error is shown below. Any idea to get rid of this while debugging?
org.eclipse.net4j.util.om.monitor.MonitorCanceledException: org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Timeout after 10001 millis
org.eclipse.net4j.signal.RemoteException: org.eclipse.net4j.util.om.monitor.MonitorCanceledException: org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Timeout after 10001 millis
at org.eclipse.net4j.signal.RequestWithConfirmation.getRemoteException(RequestWithConfirmation.java:141)
at org.eclipse.net4j.signal.RequestWithConfirmation.setRemoteException(RequestWithConfirmation.java:130)
at org.eclipse.net4j.signal.SignalProtocol.handleRemoteException(SignalProtocol.java:467)
at org.eclipse.net4j.signal.RemoteExceptionIndication.indicating(RemoteExceptionIndication.java:66)
at org.eclipse.net4j.signal.Indication.doExtendedInput(Indication.java:57)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
at org.eclipse.net4j.signal.Indication.execute(Indication.java:51)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.eclipse.net4j.util.om.monitor.MonitorCanceledException: org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Timeout after 10001 millis
at org.eclipse.net4j.util.om.monitor.Monitor.checkCanceled(Monitor.java:56)
at org.eclipse.net4j.util.om.monitor.TimeoutMonitor.checkCanceled(TimeoutMonitor.java:116)
at org.eclipse.net4j.util.om.monitor.AbstractMonitor.hasBegun(AbstractMonitor.java:36)
at org.eclipse.net4j.util.om.monitor.AbstractMonitor.checkBegun(AbstractMonitor.java:141)
at org.eclipse.net4j.util.om.monitor.AbstractMonitor.fork(AbstractMonitor.java:65)
at org.eclipse.net4j.util.om.monitor.TimeoutMonitor.fork(TimeoutMonitor.java:81)
at org.eclipse.net4j.signal.IndicationWithMonitoring.responding(IndicationWithMonitoring.java:92)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:98)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:298)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:67)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:65)
... 5 more
Caused by: org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Timeout after 10001 millis
at org.eclipse.net4j.util.om.monitor.TimeoutMonitor.handleTimeout(TimeoutMonitor.java:121)
at org.eclipse.net4j.util.om.monitor.TimeoutMonitor$1.handleTimeout(TimeoutMonitor.java:61)
at org.eclipse.net4j.util.concurrent.Timeouter$1.run(Timeouter.java:88)
at java.util.TimerThread.mainLoop(Unknown Source)
at java.util.TimerThread.run(Unknown Source)
FUDForum. Page generated in 0.07346 seconds
