Home » Eclipse Projects » Virgo » Virgo environment from inside the container
Virgo environment from inside the container [message #1017132] Sat, 09 March 2013 12:51 Go to next message
James Gartner is currently offline James Gartner
Member
Folks,
we have Virgo containers on WINDOWS servers, and also Linux boxes, and even have more than one container on a given machine.
My question is this: I need to access one of the virgo directories (repository/usr) from a service running inside the container. I also may need to read what the OS is (or other environmental items). Is there an easy programmatic way to do that, or do I need to set up something in the startup scripts? How would be the best way to approach this?
Thanks!
Re: Virgo environment from inside the container [message #1037476 is a reply to message #1017132] Tue, 09 April 2013 11:48 Go to previous message
Glyn Normington is currently offline Glyn Normington
You could infer Windows vs Linux by testing the File path separator, although it's a hack.
Another approach would be to set system properties via the startup script. Note that the startup script already sets some of these, which may be of use.
Previous Topic:Karaf feature to pom and plans transformer
Next Topic:War not "Spring Powered" despite using lots of spring
Current Time: Thu May 23 05:58:12 EDT 2013
Powered by FUDForum. Page generated in 0.01631 seconds
