| How to get the CategoryAxis in startImageMethod() (HTML Emitter) [message #1016929] |
Fri, 08 March 2013 04:00  |
Samo Gb Messages: 40 Registered: December 2012 |
Member |
Hi all,
I need to get the CategoryAxis and the IChartWithAxes includes a method to receive it.
But my problem is how to get an Object of IChartWithAxes.
I'm modifying the HTML Emitter and this is the code I use till now:
Class: HTMLReportEmitter
Method:
public void startImage(IImageContent image) {
ExecutionContext exeContext = ((ReportContent) image.getReportContent())
.getExecutionContext();
Object genby = image.getGenerateBy();
if (genby instanceof ExtendedItemDesign) {
ExtendedItemDesign mychart = (ExtendedItemDesign) image
.getGenerateBy();
long deh = mychart.getHandle().getID();
ReportDesignHandle rdh = image.getReportContent().getDesign()
.getReportDesign();
ExtendedItemHandle eih = (ExtendedItemHandle) rdh
.getElementByID(deh);
IDataQueryDefinition qd = mychart.getQuery();
try {
IDataEngine de = (IDataEngine) exeContext.getDataEngine();
QueryResultSet qr = (QueryResultSet) de.execute(qd);
IResultIterator ri = qr.getResultIterator();
int cc = ri.getResultMetaData().getColumnCount();
IResultMetaData rsmd = ri.getResultMetaData();
} catch (EngineException e2) {
e2.printStackTrace();
} catch (BirtException e2) {
try {
ChartWithAxes cwa = (ChartWithAxes) (eih.getReportItem()
.getProperty("chart.instance"));
[color="#FF0000"]IChartWithAxes icwa = (IChartWithAxes) (eih.getReportItem()
.getProperty("chart.instance"));[/color] [color="#FF0000"]// That doesn't work!![/color]
IAxis iaxisTemp = icwa.getCategoryAxis();
SG
[Updated on: Tue, 12 March 2013 06:29] Report message to a moderator
| Re: How to get an Object of IChartWithAxes in startImageMethod() (HTML Emitter) [message #1017121 is a reply to message #1017046] |
Sat, 09 March 2013 10:27   |
Member |
Hi Jason,
I get following error:
- org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
AxisFault
faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userException
faultSubcode:
faultString: org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
faultActor:
faultNode:
faultDetail:
{http://xml.apache.org/axis/}stackTrace:org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
at org.eclipse.birt.report.service.ReportEngineService.throwDummyException(ReportEngineService.java:1115)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:943)
at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
at org.eclipse.birt.report.service.actionhandler.BirtRunAndRenderActionHandler.__execute(BirtRunAndRenderActionHandler.java:76)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.presentation.aggregation.layout.EngineFragment.doService(EngineFragment.java:318)
at org.eclipse.birt.report.presentation.aggregation.AbstractBaseFragment.service(AbstractBaseFragment.java:76)
at org.eclipse.birt.report.servlet.BirtEngineServlet.__doGet(BirtEngineServlet.java:116)
at org.eclipse.birt.report.servlet.BaseReportEngineServlet.doGet(BaseReportEngineServlet.java:185)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:735)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.birt.report.servlet.BaseReportEngineServlet.service(BaseReportEngineServlet.java:116)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:384)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)
at org.eclipse.jetty.server.Server.handle(Server.java:350)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:890)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:944)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:630)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)
at java.lang.Thread.run(Thread.java:722)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2265)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:190)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:937)
... 38 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/birt/chart/model/component/Axis
at org.eclipse.birt.report.engine.emitter.html.HTMLReportEmitter.startImage(HTMLReportEmitter.java:2838)
at org.eclipse.birt.report.engine.emitter.CompositeContentEmitter.startImage(CompositeContentEmitter.java:274)
at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.startContent(ContentEmitterUtil.java:74)
at org.eclipse.birt.report.engine.layout.html.buffer.DummyPageBuffer.startContent(DummyPageBuffer.java:126)
at org.eclipse.birt.report.engine.layout.html.HTMLLeafItemLM.start(HTMLLeafItemLM.java:67)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:139)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
... 40 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.birt.chart.model.component.Axis
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
... 50 more
{http://xml.apache.org/axis/}hostname:SGOEKBAYRAK
{}:org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
... 38 more
... 40 more
... 50 more
at org.apache.axis.AxisFault.makeFault(AxisFault.java:101)
at org.eclipse.birt.report.utility.BirtUtility.makeAxisFault(BirtUtility.java:777)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:94)
Caused by: org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
... 35 more
... 38 more
... 40 more
... 50 more
When I just use List<Axis> blabla = cwa.getAxes(); and read out the axes there ist also just a categoryAxis as an boolean variable. I can't get the binding column.
SG
[Updated on: Sat, 09 March 2013 11:10] Report message to a moderator
| Re: How to get an Object of IChartWithAxes in startImageMethod() (HTML Emitter) [message #1017687 is a reply to message #1017121] |
Tue, 12 March 2013 06:28   |
Member |
Hi Jason,
is there no way to get the Category Axis?
In the book Integrating and Extending BIRT (Page 170) I've found this:
IChart chart = (IChart) rptdesign.getReportElement("Chart name");
and
IChartWithAxes chart = (IChartWithAxes) rptdesign.getReportElement("Name of...");
SO I tried it like this:
IChart ic = (IChart) image.getReportContent().getReportContext().getReportRunnable().getDesignInstance().getReportElementByID(deh);
and
IChartWithAxes icwa = (IChartWithAxes) image.getReportContent().getReportContext().getReportRunnable().getDesignInstance().getReportElementByID(deh);
I got an ClassCastException for both of them.
[Updated on: Tue, 12 March 2013 06:49] Report message to a moderator
FUDForum. Page generated in 2.74065 seconds
