| 2-step generating [message #1016999] |
Fri, 08 March 2013 09:25 |
Michal S Messages: 73 Registered: July 2011 |
Member |
one part of my model (saved in .dsl1 files) produces another .dsl1 files as the output of generator. How can I process this freshly generated files inside doGenerate method?
For example:
Step 1: file1.dsl1 is processed and file2.dsl1 is generated
Step 2: file2.dsl1 is processed and file3.txt is generated
Both steps work separately very well. If I open generated file2.dsl1 and re-save it then file3.txt is generated. The only problem is, that I don't want to open and re-save file2.dsl1 to generate file3.txt, it should be done automatically.
I guess I need to register file2.dsl1 as Resource and process this resource recursively with doGenerate method, but I don't know, how to do it...
Further explanation:
I have already built one language (DSL1) and generator for my purposes.
In future I want to design another language (DSL2) and generator. Output of DSL2 generator should be DSL1 model. DSL2 will need to access DSL1 model, which were written previously. Temporarily I just want to prepare prototype of DSL2 included in DSL1, I will split the languages later.
Thank you & Best regards
Michal
FUDForum. Page generated in 0.01528 seconds
