Home » Modeling » GMF (Graphical Modeling Framework) » After "Generate diagram code" the edit project is not found
After "Generate diagram code" the edit project is not found [message #1016919] Fri, 08 March 2013 03:33 Go to next message
Björn Rellesch is currently offline Björn Rellesch
I tried to make a simple editor. I created a ecore-file with xText. Afterwards I created the GMF files with the Dashboard. If I generate the Diagram Editor always an error occurs, that the *.edit-bundle cannot be found (see picture).
Any ideas?
I use:
Eclipse Juno 4.2.2
Xtext 2.3.1
GMF Tooling 3.0.0
EMF 2.8
Greets
Björn
  • Attachment: GMFEdit.JPG
    (Size: 83.80KB, Downloaded 22 times)
Re: After "Generate diagram code" the edit project is not found [message #1016920 is a reply to message #1016919] Fri, 08 March 2013 03:34 Go to previous messageGo to next message
Aurelien Pupier is currently offline Aurelien Pupier
did you generate the EMF model from genmodel?
Aurélien Pupier - BonitaSoft S.A.
My blog
My company Eclipse-related blog
Re: After "Generate diagram code" the edit project is not found [message #1016957 is a reply to message #1016919] Fri, 08 March 2013 05:56 Go to previous messageGo to next message
Valerian Merkling is currently offline Valerian Merkling
Member
The diagram can't run alone, you have to use your genmodel to generate the Model Code and the Edit Code (open the genmodel and right clic on the root element).
This will fill your GMF/src folder, and create a GMF.edit project.
The edit project contains the code oh the properties edition of all your EClass.
It's used by the .diagram and also by the tree editor that you can generate with the genmodel.
Re: After "Generate diagram code" the edit project is not found [message #1016970 is a reply to message #1016920] Fri, 08 March 2013 06:52 Go to previous message
thank you. I opened the genmodel-file and generated the "Edit code" by right-click.
Greets
Björn
Previous Topic:How to increase figure's selectable area?
Next Topic:Delete From Diagram
Current Time: Fri May 24 00:06:19 EDT 2013
Powered by FUDForum. Page generated in 0.01619 seconds
