| can't find org.eclipse.emf.edit.ui.EditorEntryPoint for GWT editor [message #1016529] |
Wed, 06 March 2013 14:07  |
John Yotka Messages: 143 Registered: July 2009 |
I'm using Eclipse 3.7.2, EMF 2.7.0.v20110606-0949, Google App Engine
Java SDK 1.7.5, Google Plugin for Eclipse 3.7, and Google Web Toolkit
SDK 2.5.0. I copied an EMF project and updated the .genmodel
RuntimePlatform property to GWT. I regenerated the model, edit and
editor. The generator created an xxxEditorEntryPoint.java file that
imports org.eclipse.emf.edit.ui.EditorEntryPoint. I'm unable to find
that import. also the build returns the following error:
Errors occurred during the build.
Errors running builder 'Google App Engine Project Change Notifier' on
project 'com.datria.DVA.translatePromptsGWT.editor'.
NO_MODIFICATION_ALLOWED_ERR: An attempt is made to modify an object
where modifications are not allowed.
| Re: can't find org.eclipse.emf.edit.ui.EditorEntryPoint for GWT editor [message #1016775 is a reply to message #1016609] |
Thu, 07 March 2013 11:39   |
On 3/6/2013 11:55 PM, Ed Merks wrote:
> John,
> Did you provision your target platform with the EMF GWT runtime?
Ed,
No I didn't, is there a writeup on how to do that?
| Re: can't find org.eclipse.emf.edit.ui.EditorEntryPoint for GWT editor [message #1016790 is a reply to message #1016775] |
Thu, 07 March 2013 12:10  |
Ed Merks Messages: 24560 Registered: July 2009 |
John,
Sorry, it's a bit out of date: http://wiki.eclipse.org/EMF/GWT
>> John,
> Ed,
FUDForum. Page generated in 0.06861 seconds
