| HTML Emitter - How to get the axis description of the charts [message #1010944] |
Mon, 18 February 2013 09:24  |
Samo Gb Messages: 40 Registered: December 2012 |
Member |
I'm modifying the HTML emitter and want to know if there is any possibility to get the axis description of bar charts. Better would be information about the dataset.
I want to read out the entire Information about charts.
In this class:
org.eclipse.birt.report.engine.emitter.html.HTMLReportEmitter.java
is a method startImage() which receives an image with some informations about the bars but I also need the information about the axis, about the chart type and so on.
How does the startImage() method works and how the method is called?
[Updated on: Mon, 18 February 2013 09:37] Report message to a moderator
| Re: HTML Emitter - How to get the axis description of the charts [message #1011110 is a reply to message #1011051] |
Mon, 18 February 2013 16:55   |
Member |
Hi Jason,
Thank you for replying.
I just copied your code in the method and got following error:
org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
AxisFault
faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userException
faultSubcode:
faultString: org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
faultActor:
faultNode:
faultDetail:
{http://xml.apache.org/axis/}stackTrace:org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
at org.eclipse.birt.report.service.ReportEngineService.throwDummyException(ReportEngineService.java:1115)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:943)
at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
at org.eclipse.birt.report.service.actionhandler.BirtRunAndRenderActionHandler.__execute(BirtRunAndRenderActionHandler.java:76)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.presentation.aggregation.layout.EngineFragment.doService(EngineFragment.java:318)
at org.eclipse.birt.report.presentation.aggregation.AbstractBaseFragment.service(AbstractBaseFragment.java:76)
at org.eclipse.birt.report.servlet.BirtEngineServlet.__doGet(BirtEngineServlet.java:116)
at org.eclipse.birt.report.servlet.BaseReportEngineServlet.doGet(BaseReportEngineServlet.java:185)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:735)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.birt.report.servlet.BaseReportEngineServlet.service(BaseReportEngineServlet.java:116)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:384)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)
at org.eclipse.jetty.server.Server.handle(Server.java:350)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:890)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:944)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:630)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)
at java.lang.Thread.run(Thread.java:722)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2265)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:190)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:937)
... 38 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/birt/chart/model/Chart
at org.eclipse.birt.report.engine.emitter.html.HTMLReportEmitter.startImage(HTMLReportEmitter.java:3033)
at org.eclipse.birt.report.engine.emitter.CompositeContentEmitter.startImage(CompositeContentEmitter.java:274)
at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.startContent(ContentEmitterUtil.java:74)
at org.eclipse.birt.report.engine.layout.html.buffer.DummyPageBuffer.startContent(DummyPageBuffer.java:126)
at org.eclipse.birt.report.engine.layout.html.HTMLLeafItemLM.start(HTMLLeafItemLM.java:67)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:139)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
... 40 more
{http://xml.apache.org/axis/}hostname:SGOEKBAYRAK
{}:org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
... 38 more
... 40 more
at org.apache.axis.AxisFault.makeFault(AxisFault.java:101)
at org.eclipse.birt.report.utility.BirtUtility.makeAxisFault(BirtUtility.java:777)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:94)
Caused by: org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
... 35 more
... 38 more
... 40 more
I debugged the Emitter with your code.
In this line : Chart cm = (Chart) (eih.getReportItem().getProperty("chart.instance"));
it jumps out of my code and I get the error above.
It's not jumping in the catch block.
When I try this:
System.out.println(eih.getReportItem().toString());
System.out.println(eih.getReportItem().getProperty("chart.instance"));
I do get a output without an error.
Samet
[Updated on: Tue, 19 February 2013 11:24] Report message to a moderator
FUDForum. Page generated in 0.03049 seconds
