Home » Modeling » OCL » [OCLinEcore] Invalid way of specifying cardinality
[OCLinEcore] Invalid way of specifying cardinality [message #1016641] Thu, 07 March 2013 03:57 Go to next message
Cedric Moonen is currently offline Cedric Moonen
This notation for the cardinality is accepted by the OCLinEcore editor:
property value : ecore::EDouble[3];
You would suppose that it resolves to a lower and a upper bound of 3 but this is converted to 0 to 1 (so similar as a '?').
IMHO, this syntax should either be refused (you have to specify [3..3]) or it should resolve to 3 for the lower and upper bounds.
Cédric
Re: [OCLinEcore] Invalid way of specifying cardinality [message #1017052 is a reply to message #1016641] Fri, 08 March 2013 13:42 Go to previous message
Thanks. I'm surprised this has crept through.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=402767 raised.
The UML specification is the guide here; although clumsily worded, there
is no doubt that [3] is a short form for [3..3].
Fix currently under test. Hopefully committed to master tonight.
REgards
Ed Willink
On 07/03/2013 08:57, Cedric Moonen wrote:
> Hello,
> Cédric
Previous Topic:Synchronization issues betwee CompleteOCL editor and model editor
Next Topic:cannot get tutorial to create error
Current Time: Sun May 19 00:07:15 EDT 2013
Powered by FUDForum. Page generated in 0.01567 seconds
