Home » Modeling » QVT-Relations » [help]QVTd as a parser in a standalone application
[help]QVTd as a parser in a standalone application [message #1015205] Wed, 27 February 2013 12:56 Go to next message
Tiago Guimarães is currently offline Tiago Guimarães
I'm in need for a QVTr parser for my application, since QVTd uses EMF it appear to me as the best choice.
It's still my first time using a parser created in Xtext, so I tried to follow the example on Xtext FAQ (http://wiki.eclipse.org/Xtext/FAQ#How_do_I_load_my_model_in_a_standalone_Java_application.C2.A0.3F) with little success.
I dont know wich QVTd package I should be using, and what should I add to the build path...
Injector injector = new QVTrelationStandaloneSetup().createInjectorAndDoEMFRegistration();
Right now, that line is giving me the following exception:
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/ocl/examples/xtext/essentialocl/EssentialOCLStandaloneSetup
	at org.eclipse.qvtd.xtext.qvtrelation.QVTrelationStandaloneSetupGenerated.createInjectorAndDoEMFRegistration(QVTrelationStandaloneSetupGenerated.java:20)
	at TesteQVT.main(TesteQVT.java:26)
Thanks in advance,
Tiago Guimarães
Re: [help]QVTd as a parser in a standalone application [message #1015222 is a reply to message #1015205] Wed, 27 February 2013 14:47 Go to previous messageGo to next message
If you're running stanalone then you should call
QVTrelationStandaloneSetup.doSetUp(), thereafter you can just use
ResourceSet.getResource() to load a *.qvtr file.
You add to the build path until you get no errors, but if you use a
Plugin project rather than a java p[roject, Eclipse does uit for you.
Ed Willink
On 27/02/2013 19:25, Tiago Guimarães wrote:
> Hello,
> at
> Thanks in advance,
> Tiago Guimarães
Re: [help]QVTd as a parser in a standalone application [message #1015956 is a reply to message #1015205] Mon, 04 March 2013 07:06 Go to previous messageGo to next message
Hi again,
so i followed your suggestion and I used the following code:
QVTrelationStandaloneSetup.doSetup();
XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
resourceSet.getResource(URI.createFileURI("AbstractToConcrete.qvtr"), true);
This worked fine, i could use resourceSet.getResources() later to get the contents...
But then i noticed, that what i wanted was not QVTrelation, but QVTrelationPivot, because we were using EMF genereted code from OMG's QVTrelations ecore, and QVTrelationPivot seemed the way to go, so i changed the code into this:
QVTrelationPivotStandaloneSetup.doSetup();
Injector injector = new QVTrelationPivotStandaloneSetup().createInjectorAndDoEMFRegistration();
by doing this i got an exception on the last line:
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.xml.sax.SAXParseExceptionpublicId: AbstractToConcrete.qvtr; systemId: file:///home/tmg/workspace/TesteQVTd/AbstractToConcrete.qvtr; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.
Thanks in advance
Tiago Guimarães
Re: [help]QVTd as a parser in a standalone application [message #1015964 is a reply to message #1015956] Mon, 04 March 2013 07:32 Go to previous messageGo to next message
QVTr is a complex language with distinct (Xtext-friendly) CST and
(OMG-compliant) AST.
QVTrelationStandaloneSetup.doSetup() initializes the CST (and AST)
QVTrelationPivotStandaloneSetup.doSetup() only initialaizes the AST, so
won't do very much.
Have a look at
GIT\org.eclipse.qvtd\tests\org.eclipse.qvtd.xtext.qvtrelation.tests to
see some standalone code loading, parsing, and saving QVTr files.
You should not need to create an injector.
Ed Willink
On 04/03/2013 12:06, Tiago Guimarães wrote:
> Hi again,
> true);
> the contents...
> true);
> systemId:
> Thanks in advance
> Tiago Guimarães
Re: [help]QVTd as a parser in a standalone application [message #1016424 is a reply to message #1015205] Wed, 06 March 2013 07:08 Go to previous messageGo to next message
Thanks for your help!
I just have a simple problem with the results now:
I can't tell when a relation is Top or not...
The method I am using is relation.isIsTopLevel() (org.eclipse.qvtd.pivot.qvtrelation.Relation) and it is always returning false...Everything else is working fine, even OCL constraints
I have also noted that on the editor, I can't find the top attribute
Best,
Tiago Guimarães
Re: [help]QVTd as a parser in a standalone application [message #1016559 is a reply to message #1016424] Wed, 06 March 2013 17:28 Go to previous message
Oops. 'top' is not copied from CST to AST. Fix pushed to GIT master. Fix
downloadable now from
https://hudson.eclipse.org/hudson/job/buckminster-mmt-qvtd-kepler/lastSuccessfulBuild/artifact/.
Should be available on the download page and nightly update site tomorrow.
Ed Willink
> Best,
> Tiago Guimarães
Previous Topic:[Announce] Eclipse QVTd 0.10.0 (Kepler) M5 is now available
Next Topic:objectsOfType don`t return correct results
Current Time: Tue May 28 20:53:20 EDT 2013
Powered by FUDForum. Page generated in 0.01613 seconds
