Home » Modeling » TMF (Xtext) » Scoping of references in my DSL
Scoping of references in my DSL [message #1016492] Wed, 06 March 2013 11:43 Go to next message
Marco Naddeo is currently offline Marco Naddeo
Member
Hi all Smile
My DSL grammar defines a base expression in this way:
BaseExpression:
  ( t='this' |
    res+=SuperExpression |
    t='true' |
    t='false' |
    t=FLOAT_LITERAL |
    t=INTEGER_LITERAL |
    t=BYTE_LITERAL |
    t=STRING_LITERAL |
    t='null' |
    ref=[Variable] |
    '(' res+=Expression ')' |
    res+=ObjectCreation
  ) ( res+=MethodCallSuffix | res+=FieldSelectSuffix )*
MethodCallSuffix:
  '.' methodMixin=[MixinDeclaration] '.' methodName=[MethodDeclaration|FQN] list=ActualParameters
FieldSelectSuffix:
  '.' mixinName=[MixinDeclaration] '.' fieldName=[FieldDeclaration|FQN]
I'd like to scope the MixinDeclaration references in last two rules to limit the referenceable mixins.
To do that, I'm trying to define two methods in my DSLScopeProvider:
IScope scope_MethodCallSuffix_methodMixin(BaseExpression expr, EReference mixin) {
IScope scope_FieldSelectSuffix_mixinName(BaseExpression expr, EReference mixin) {
The referenceable mixins depends on what precedes the '.', but I don't understand how I can obtain this previous element. For example, if before I have a MethodCallSuffix, then I have to consider the return type of the previous called method; if I have a variable or object creation, the type of this object; and so on.
Could you please help me? Is there somewhere an example of a similar scoping?
Thanks in advance,
Marco
Re: Scoping of references in my DSL [message #1016500 is a reply to message #1016492] Wed, 06 March 2013 12:01 Go to previous message
Christian Dietrich is currently online Christian Dietrich
you might get some ideas from here:
http://dslmeinte.wordpress.com/2011/11/23/path-expressions-in-entity-models-revisited/
http://dslmeinte.wordpress.com/2010/08/16/path-expressions-in-entity-models/
Alerternatively consider to use Xbase/JvmModelinferrer to get most of it 4 free.
Previous Topic:Xtext editor with pages
Next Topic:Strange behavior of INT
Current Time: Tue May 21 13:31:08 EDT 2013
Powered by FUDForum. Page generated in 0.01597 seconds
