Home » Modeling » MoDisco » Modisco & Papyrus don't generate UML
Modisco & Papyrus don't generate UML [message #1016020] Mon, 04 March 2013 10:46 Go to next message
Marco Tirelli is currently offline Marco Tirelli
I have recently installed Modisco & Papyrus for create a UML diagram of my Java/Android project.
Now i right-clicked on Project & selected Discovery -> Discoveries - > Discover Java Project. This was successful & it gave me a .xmi file.
But when i right-clicked on the xmi file & selected Discovery -> Discoveries -> Generate UML model from KDM model, this don't gave me the .uml file.
Do you know what is the reason?
Re: Modisco & Papyrus don't generate UML [message #1016039 is a reply to message #1016020] Mon, 04 March 2013 11:54 Go to previous messageGo to next message
Hugo Bruneliere is currently offline Hugo Bruneliere
From what I understood, you managed to get a Java model out of your Java project using the first action you are mentioning.
Thus you first have to obtain a KDM model before being able to transform it into UML (thanks to the so-called "UML to KDM" action).
You must make a call, from your Java model, to the "Java to KDM" action.
Note that the "KDM to UML" feature may currently not work on some Java projects and corresponding models.
We are working on solving this bug and a fix will be integrated within the next MoDisco releases.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Re: Modisco & Papyrus don't generate UML [message #1016135 is a reply to message #1016039] Tue, 05 March 2013 03:10 Go to previous messageGo to next message
Yes,
I have generated the KDM file (my_program_kdm.xmi) and i've used the call "Discover UML model from KDM model..." but it don't create the corresponding UML in my project (the SERIALIZE_TARGET parameter is true).
Thank's for the answer
Re: Modisco & Papyrus don't generate UML [message #1016137 is a reply to message #1016039] Tue, 05 March 2013 03:12 Go to previous messageGo to next message
No Message Body
[Updated on: Tue, 05 March 2013 03:13]
Report message to a moderator
Re: Modisco & Papyrus don't generate UML [message #1016196 is a reply to message #1016137] Tue, 05 March 2013 08:00 Go to previous messageGo to next message
So it seems that, in your case, the bug I've mentioned is occurring.
We are working on in integrating the fix as soon as possible to the MoDisco releases.
In the meantime, you can get the source of the corresponding plugin and apply the provided patch manually (cf. Bug #376144).
Hugo
Nantes - France
Re: Modisco & Papyrus don't generate UML [message #1016213 is a reply to message #1016196] Tue, 05 March 2013 09:13 Go to previous messageGo to next message
To be complete, the very recently released MoDisco Juno SR2 version already integrates the fix that should solve the problem in many cases.
Hugo
Nantes - France
Re: Modisco & Papyrus don't generate UML [message #1016457 is a reply to message #1016213] Wed, 06 March 2013 09:10 Go to previous message
I have done the upload and now it works perfectly; thank you very much.
Marco
Previous Topic:How to process my KDM models
Next Topic:Small API break to be compatible with Helios
Current Time: Tue May 28 18:50:04 EDT 2013
Powered by FUDForum. Page generated in 1.87257 seconds
