| Re: [Zest] Different Connections [message #1017113 is a reply to message #1017006] |
Sat, 09 March 2013 08:17  |
Vitaly Savickas Messages: 58 Registered: March 2010 |
Member |
Fair enough:) However, I believe you don't want to select both connections all the time, only when you select the segment that is common. This adds additional complexity, but can be done, as Andreas Muelder suggested me in a different topic, by fiddling with selection requests.
I believe other developers including myself would very much appreciate if you could post a solution as you implement this feature;)
Vitaly
FUDForum. Page generated in 0.02179 seconds
