Home » Eclipse Projects » Jubula » Can i delete user defined project from Default database in jubula
Can i delete user defined project from Default database in jubula [message #1016397] Wed, 06 March 2013 05:58 Go to next message
Yuga M is currently offline Yuga M
Can i delete user defined project from Default database in jubula.
i want to re-create a project with the same name in the database. for that purpose i have to delete the currently existing project from database. can some one please tell me how to delete the existing projects.
Re: Can i delete user defined project from Default database in jubula [message #1016398 is a reply to message #1016397] Wed, 06 March 2013 06:06 Go to previous message
Achim Loerke is currently offline Achim Loerke
If you can open a project then you should be able to delete it. Just have a look in the menu where open is located or (if you use keyboard shortcuts) guess what could be used (hint: [O]pen, [D]elete).
Reading the documentation might help, too. We've put a great amount of work into it, but it seems no one is reading it.
- Achim
Previous Topic:Jubula test case/test steps data model
Next Topic:Jubla Support For 3rd party Swing Api
Current Time: Sat May 25 04:26:14 EDT 2013
Powered by FUDForum. Page generated in 0.01459 seconds
