Home » Eclipse Projects » Remote Application Platform (RAP) » RAP Textfield problem
RAP Textfield problem [message #1016224] Tue, 05 March 2013 09:43 Go to next message
Jens L is currently offline Jens L
i have the following simple Textfield
Text password = new Text( compInput, SWT.BORDER | SWT.PASSWORD);
i saved the value of these textfield in an ClientStore for the next start.
 ClientStore store = RWT.getClient().getService(ClientStore.class);
 String passwordValue = store.get("Password");
 passwort.setText(passwordValue);
My problem is that the method setText() from Text class is being called two times. And after these two calls the length from textfield getting greater.
For example:
Value for textfield after first call of setText(): "password"
Value for textfield after second call of setText(): "password "
I debuged this problem and find the following:
in class ClientMessage (Version RAP 2.0 R) i became at line 217 the following JSONObject during the second call of the setText() method:
{"text":"password\u200b","selectionStart":0,"selectionLength":0}
My question is why is the character with the Unicode \u200b in the text parameter and why is the method setText two times call ?
Re: RAP Textfield problem [message #1016618 is a reply to message #1016224] Thu, 07 March 2013 02:40 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan Furnadjiev
Hi Jens,
the character \u200b is 'zero width space' character. What Tabris
platform are you using - Android or iOS?
Best,
Ivan
> start.
> getting greater.
> For example:
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: RAP Textfield problem [message #1016626 is a reply to message #1016618] Thu, 07 March 2013 03:19 Go to previous messageGo to next message
I use both platforms but the problem only occur on the android platform
Re: RAP Textfield problem [message #1016639 is a reply to message #1016224] Thu, 07 March 2013 03:46 Go to previous message
Moritz Post is currently offline Moritz Post
Hi. Thanks for raising your issue.
Regarding the empty space character in the text field: That is a known tabris android bug and will be fixed in the next release.
For your setText being called twice... The code you pasted should not get called twice so it has probably something to do with your code setup. More insights would be needed.
Btw... for direct feedback on tabris related questions you should use the tabris issue tracker on github.com/eclipsesource/tabris
Previous Topic:Table selection issue
Next Topic:Image Map
Current Time: Wed May 22 19:22:51 EDT 2013
Powered by FUDForum. Page generated in 0.01588 seconds
