Home » Modeling » Epsilon » delete from diagram button always Disabled(Eugenia)
delete from diagram button always Disabled [message #1016141] Tue, 05 March 2013 03:25 Go to next message
serhat gezgin is currently offline serhat gezgin
Hi all,
First of all i m new to GMF and Eugenia.
Problem;
When i create diagram from eugenia always delete from diagram button is disabled.
So what i must do, i need these button cause of working large models. Anyone can help me ?
[Updated on: Thu, 07 March 2013 08:23]
Report message to a moderator
Re: delete from diagram button always Disabled [message #1016652 is a reply to message #1016141] Thu, 07 March 2013 04:22 Go to previous messageGo to next message
Antonio Garcia-Dominguez is currently offline Antonio Garcia-Dominguez
Hi serhat,
I've just tried generating an editor with Eugenia, and I see a "Remove from Model" but not a "Remove from Diagram" button. Which version of Eclipse and which perspective are you using?
Re: delete from diagram button always Disabled [message #1016710 is a reply to message #1016652] Thu, 07 March 2013 07:49 Go to previous messageGo to next message
Eclipse 4.2 Juno and Epsilon or Java or Ecore Perspective dont bother always i see 2
delete command 1. is Delete From model 2. is Delete From Diagram. But Delete from
diagram always disabled not clickable.
Re: delete from diagram button always Disabled [message #1016811 is a reply to message #1016710] Thu, 07 March 2013 13:35 Go to previous message
Apparently, "Delete from Diagram" is not available for GMF-based editors by default. Please have a look at these links:
http://www.eclipse.org/forums/index.php/m/512204/
https://code.google.com/p/gmftools/wiki/SemiCanonicalDiagramEditPolicy
http://www.eclipse.org/forums/index.php/t/60363/
Previous Topic:EOL
Next Topic:EVL-Validating from a node different of root not working until root validation is made
Current Time: Sat May 18 22:08:56 EDT 2013
Powered by FUDForum. Page generated in 0.08183 seconds
