Home » Modeling » M2T (model-to-text transformation) » XPand Debug(I cant Debug my Xpand project)
XPand Debug [message #1007171] Mon, 04 February 2013 12:12 Go to next message
serhat gezgin is currently offline serhat gezgin
I cant debug my xpand project i always get
Debugger runtime process didn't respond properly --> aborting
Eror.
How can i fix this ?
Re: XPand Debug [message #1007198 is a reply to message #1007171] Mon, 04 February 2013 17:16 Go to previous messageGo to next message
Christian Dietrich is currently online Christian Dietrich
which Xpand Version do you use?
~Christian
Re: XPand Debug [message #1007199 is a reply to message #1007198] Mon, 04 February 2013 17:23 Go to previous messageGo to next message
Btw do you get a stack trace?
Re: XPand Debug [message #1007227 is a reply to message #1007198] Tue, 05 February 2013 02:01 Go to previous messageGo to next message
i use Eclipse juno with Xpand sdk 1.2.1
[Updated on: Tue, 05 February 2013 02:02]
Report message to a moderator
Re: XPand Debug [message #1007230 is a reply to message #1007199] Tue, 05 February 2013 02:05 Go to previous messageGo to next message
Console output ;
0 INFO WorkflowEngine - --------------------------------------------------------------------------------------
3 INFO WorkflowEngine - EMF Modeling Workflow Engine 1.2.1, Build v201206110920
4 INFO WorkflowEngine - (c) 2005-2009 openarchitectureware.org and contributors
4 INFO WorkflowEngine - --------------------------------------------------------------------------------------
4 INFO WorkflowEngine - running workflow: C:/Users/unituser/workspace/com.unitbilisim.clafer2Ecore/src/workflow/Workflow.mwe
370 INFO XSDMetaModel - Loading XSDSchema from 'metamodel/ir.xsd'
1177 INFO OawXSDEcoreBuilder - Creating EPackage 'ir' from XSDSchema 'file:/.../bin/metamodel/ir.xsd' (http://clafer.org/ir)
1211 WARN OawXSDEcoreBuilder - Name Conflict: Created EClass 'EndType1', EClass 'EndType' is in the way. Container:/EPackage'ir'
1212 WARN OawXSDEcoreBuilder - Name Conflict: Created EClass 'PositionType1', EClass 'PositionType' is in the way. Container:/EPackage'ir'
1213 WARN OawXSDEcoreBuilder - Name Conflict: Created EClass 'StartType1', EClass 'StartType' is in the way. Container:/EPackage'ir'
Warning: Element can't be debugged.
Didn't find an adapter for element of type XMLReader
1357 INFO CompositeComponent - XMLReader: Loading XML file model/lightCase10.xml
3755 INFO OawEcoreBuilder - Already loaded EPackage requested. Namespace:http://clafer.org/ir
3869 INFO CompositeComponent - Generator: generating 'template::DeepTravelTemplate::Root FOR model' => src-gen
4363 INFO Generator - Written 1 files to outlet [default](src-gen)
4364 ERROR WorkflowEngine -
at org.eclipse.emf.mwe.internal.core.debug.processing.DebugMonitor.finished(DebugMonitor.java:231)
at org.eclipse.emf.mwe.core.WorkflowEngine.executeWorkflow(WorkflowEngine.java:175)
at org.eclipse.emf.mwe.core.WorkflowEngine.run(WorkflowEngine.java:53)
at org.eclipse.emf.mwe.core.WorkflowRunner.doRun(WorkflowRunner.java:174)
at org.eclipse.emf.mwe.core.WorkflowRunner.main(WorkflowRunner.java:70)
Re: XPand Debug [message #1007415 is a reply to message #1007230] Tue, 05 February 2013 13:59 Go to previous messageGo to next message
i can reproduce this using the example project from the wizard.
please file a bugzilla if there isnt already one.
~Christian
Re: XPand Debug [message #1008392 is a reply to message #1007415] Tue, 12 February 2013 04:58 Go to previous messageGo to next message
When i create Xpand example (auto generated from xpand) and want to debug, i have same
error too. But why ? Don't understand
Re: XPand Debug [message #1008400 is a reply to message #1008392] Tue, 12 February 2013 05:32 Go to previous messageGo to next message
AS i said Please file a bug
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: XPand Debug [message #1015972 is a reply to message #1007171] Mon, 04 March 2013 07:57 Go to previous message
Karsten Thoms is currently offline Karsten Thoms
You could debug Java as workaround, if you check the option "Java debug" in the launch config.
Need professional support for Xtext, Xpand, EMF?
Go to: http://xtext.itemis.com
Twitter : @kthoms
Blog : www.karsten-thoms.de
Previous Topic:transformation from AADl to TXT
Next Topic:Sharing JET2 templates between transformations
Current Time: Wed May 22 03:20:14 EDT 2013
Powered by FUDForum. Page generated in 0.02725 seconds
