| How to add new Layers and show specific figures in Them? [message #526839] |
Tue, 13 April 2010 04:32  |
Vijay Raj Messages: 604 Registered: July 2009 |
Can any body point to a piece of code or example where a new layer addition ( like connection and gridlayer) has been done...
After doing that how can i tell the editpart that my figure should be added in the above layer??
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
[Updated on: Tue, 13 April 2010 04:50] Report message to a moderator
| Re: How to add new Layers and show specific figures in Them? [message #1015951 is a reply to message #1015926] |
Mon, 04 March 2013 06:54  |
Jan Krakora Messages: 402 Registered: December 2009 Location: Prague |
you can do that by exdending RootEditPart:
public class CustomScalableFreeformRootEditPart extends ScalableFreeformRootEditPart {
public static final String CUSTOM_LAYER = "Custom layer";
protected void createLayers(LayeredPane layeredPane) {
super.createLayers(layeredPane);
FreeformLayer customLayer = new FreeformLayer();
customLayer .setLayoutManager(new FreeformLayout());
layeredPane.addLayerAfter(customLayer , CUSTOM_LAYER, LayerConstants.SCALABLE_LAYERS);
Then in the EditPart that is parent of the EditPart being added to the custom layer:
public class ParentEditPart extends AbstractGraphicalEditPart {
protected void addChildVisual(EditPart childEditPart, int index) {
IFigure child = ((GraphicalEditPart) childEditPart).getFigure();
if (childEditPart instanceof CustomEditPart) {
getLayer(CustomScalableFreeformRootEditPart.CUSTOM_LAYER).add(child, index);
} else {
super.add(child, index);
protected void removeChildVisual(EditPart childEditPart) {
getLayer(CustomScalableFreeformRootEditPart.CUSTOM_LAYER).remove(index);
} else {
super.remove(child);
Note that the code above will probably throw exceptions because of wrong index.
This is because model indexes are not sync with visual indexes.
(The model of CustomEditPart is eg at index 1, but the visual representation is at index 0)
So you have to reimplement indexing or don't use indexing at all. (*.add(child, -1))
FUDForum. Page generated in 0.07807 seconds
