Home » Language IDEs » Java Development Tools (JDT) » Creating a Tomcat Server in Eclipse
Creating a Tomcat Server in Eclipse [message #959990] Sat, 27 October 2012 00:57 Go to next message
Magnus Warker is currently offline Magnus Warker
I wanted to change from Tomcat 6 to Tomcat 7 in Eclipse.
So I deleted my Tomcat 6 Server and wanted to define a Tomcat 7 server.
However, when I choose to create a new server (Servers->New->Other->Server->Server), the "Finish" button is disabled.
The default server type is "Tomcat 6", the host name is "localhost" and the server name is empty. I cannot enter anything into server name. And the "Finish" button is disabled.
It does not change anything when I select "Tomcat 7".
How can I create a server again?
Why is Tomcat 6 preselected?
And a totally different question:
My GWT Project still works. Doesn't it use the Tomcat server?
Magnus
Re: Creating a Tomcat Server in Eclipse [message #1008077 is a reply to message #959990] Fri, 08 February 2013 14:15 Go to previous messageGo to next message
William Peloquin is currently offline William Peloquin
Did you ever get a solution to loading Tomcat 7? I am having the same problem with not server name being displayed.
Willie
Re: Creating a Tomcat Server in Eclipse [message #1008098 is a reply to message #959990] Fri, 08 February 2013 17:47 Go to previous messageGo to next message
Eclipse User
You must do a Windows->Preferences->Server->Runtimes and create a Tomcat
7 runtime by pointing to an installed JRE and an installed Tomcat 7
installation. Only then can create a server instance for it.
Rich
Re: Creating a Tomcat Server in Eclipse [message #1015757 is a reply to message #1008098] Sat, 02 March 2013 04:42 Go to previous message
John Mark is currently offline John Mark
hey you can try this
Previous Topic:2 problem with j2ee
Next Topic:Problem in using javascript file in Eclipse Indigo
Current Time: Thu May 23 05:30:38 EDT 2013
Powered by FUDForum. Page generated in 0.01818 seconds
