Home » Modeling » UML2 » Problem loading a UML model with a profile applied
| Problem loading a UML model with a profile applied [message #1015482] |
Thu, 28 February 2013 11:58  |
Alfredo Motta Messages: 41 Registered: June 2012 |
Member |
Hello everybody,
I have the following elements
1)A UML profile saved in a eclipse plugin.
2)Another eclipse plugin loading in Java a UML model with the previously defined UML profile applied.
The eclipse plugin is using the following lines to load the profile
Map<URI,URI> uriMap = set.getURIConverter().getURIMap();
URI uml_resource_uri = URI.createURI("jar:file:/path/to/my/plugin/jar/");
uriMap.put(URI.createURI("pathmap://resources/"), uml_resource_uri.appendSegment("resources").appendSegment(""));
where "pathmap://resources/" has been defined in the UML profile plugin
<extension
point="org.eclipse.emf.ecore.uri_mapping">
<mapping
source="pathmap://resources/"
target="platform:/plugin/path/to/the/profile">
</mapping>
</extension>
This mechanism works, i.e., I am able to load a UML model with the profile applied and to read the stereotypes.
However I want to use a different mechanism to avoid using the path to the profile in the code, i.e. URI uml_resource_uri = URI.createURI("jar:file:/path/to/my/plugin/jar/");
Reading this tutorial it seems possible
http://wiki.eclipse.org/MDT/UML2/FAQ#What.27s_required_to_load_a_UML_.28.uml.29_resource_from_a_standalone_application.3F
but I have not been able to do that
Any help?
Thank you
[Updated on: Thu, 28 February 2013 12:00] Report message to a moderator
| Re: Load profile in Eclipse plugin project [message #1015493 is a reply to message #1015484] |
Thu, 28 February 2013 14:03   |
Member |
Dear Ed,
thank you for your help. I read your links but I am not sure I got the point.
My application that is loading the UML model is an Eclipse plugin, not a simple standalone Java application. Does this make any difference?
From the wiki my understanding is that in the plugin reading the model I can use these extension points
* org.eclipse.emf.ecore.generated_package
* org.eclipse.emf.ecore.extension_parser
* and org.eclipse.emf.ecore.uri_mapping
to skip these lines
This is the text of the wiki I am referring to
In order to load a UML (.uml) resource, the package (schema), resource factory, and "pathmaps" for UML need to be registered. On the Eclipse platform, this is done through the org.eclipse.emf.ecore.generated_package, org.eclipse.emf.ecore.extension_parser, and org.eclipse.emf.ecore.uri_mapping extension points (see the plug-in manifests for the org.eclipse.uml2.uml and org.eclipse.uml2.uml.resources plug-ins).
am I wrong?
Thank you
[Updated on: Thu, 28 February 2013 14:05] Report message to a moderator
| Re: Load profile in Eclipse plugin project [message #1015577 is a reply to message #1015497] |
Fri, 01 March 2013 04:25   |
Member |
Quote:I've no idea what on earth you're trying to do.
I started using a standalone Java application to load my models and now I am trying to move away and use the Eclipse platform (but I have no big expertise on that).
Quote:But "jar:file:/path/to/my/plugin/jar/" only makes sense in a standalone
context for which I provided some links.
I completely agree that those lines are stupid in an Eclipse context.
What should I do then? I have no clue on how to use org.eclipse.emf.ecore.generated_package, org.eclipse.emf.ecore.extension_parser, and org.eclipse.emf.ecore.uri_mapping. Any documentation/tutorial around?
This is what I tried out to leave out the same lines for the UML metamodel/libraries/profiles, but I did not succeed.
I replaced this code
ResourceSet set = new ResourceSetImpl();
set.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
set.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
URI uml_resource_uri = URI.createURI("jar:file:/C:/Users/motta/Desktop/Dottorato/UML2ZOT/eu.mades.uml2zot/lib/org.eclipse.uml2.uml.resources_4.0.0.v20120604-0919.jar!/"); // for example
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uml_resource_uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uml_resource_uri.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uml_resource_uri.appendSegment("profiles").appendSegment(""));
with the previously mentioned extensions in my plugin.xml
<extension
id="pathmap://UML_LIBRARIES/"
<mapping
source="pathmap://UML_LIBRARIES/"
target="platform:/plugin/org.eclipse.uml2.uml.resources/libraries/">
</mapping>
</extension>
<extension
<mapping
source="pathmap://UML_PROFILES/"
target="platform:/plugin/org.eclipse.uml2.uml.resources/profiles/">
</mapping>
</extension>
<extension
<mapping
source="pathmap://UML_METAMODELS/"
target="platform:/plugin/org.eclipse.uml2.uml.resources/metamodels/">
</mapping>
</extension>
<extension
point="org.eclipse.emf.ecore.extension_parser">
<parser
class="org.eclipse.uml2.uml.internal.resource.UMLResourceFactoryImpl"
type="uml">
</parser>
</extension>
<extension
point="org.eclipse.emf.ecore.generated_package">
<package
class="org.eclipse.uml2.uml.UMLPackage"
uri="http://www.eclipse.org/uml2/4.0.0/UML">
</package>
</extension>
But this way is not working anymore, i.e. my imports are not resolved (for example if I refer to an Integer primitive type in my model, he is not able to find it)
Is it the correct way of using these extensions?
Thank you for your help
[Updated on: Fri, 01 March 2013 04:26] Report message to a moderator
| Re: Load profile in Eclipse plugin project [message #1015644 is a reply to message #1015577] |
Fri, 01 March 2013 09:04   |
Christian W. Damus Messages: 551 Registered: July 2009 |
Hi, Alfredo,
In the Eclipse context, EMF's and UML's plug-in extensions do
everything for you. Your code is going out of the way to undo what
Eclipse is already doing.
You can reduce your latest code excerpt to just this:
-------- 8< --------
-------- >8 --------
You don't need to add any URI mapping, extension parser, generated
package, or other extensions in your own plugin.xml. These are already
provided by the UML plug-in.
HTH,
Christian
On 2013-03-01 09:25:41 +0000, Alfredo Motta said:
> Quote:
> I started using a standalone Java application to read my models and now
> Quote:
> // for example
> <extension
> <mapping
> </mapping>
> </extension>
> <extension
> <mapping
> </mapping>
> </extension>
> <extension
> <mapping
> </mapping>
> </extension>
> <extension
> <parser
> type="uml">
> </parser>
> </extension>
> <extension
> <package
> </package>
> </extension>
> Is it the correct way of using these extensions? Thank you for your help
| Re: Load profile in Eclipse plugin project [message #1015659 is a reply to message #1015577] |
Fri, 01 March 2013 10:02   |
Member |
I solved like this
//A collection of related persistent documents.
//Register the UML Package
set.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.PROFILE_FILE_EXTENSION, UMLResource.Factory.INSTANCE );
URI uml_resource_uri = URI.createPlatformPluginURI("org.mycompanyname.profileplugin", true);
uml_resource_uri = URI.createPlatformPluginURI("org.eclipse.uml2.uml.resources", true);
With this code and running the application as an Eclipse application
I am able to load the model correctly with my profile and the UML metamodel/libraries/profiles.
The code is not anymore dependent on the paths of my machine
PS: an alternative is to use the extensions of the plugin.xml as I said previously, but I have to check. Previously I was not running my code as an Ecliplse application, therefore it was not working. My fault.
[Updated on: Fri, 01 March 2013 10:05] Report message to a moderator
| Re: Load profile in Eclipse plugin project [message #1015696 is a reply to message #1015659] |
Fri, 01 March 2013 14:14   |
Hi, Alfredo,
I'm glad that it's working for you now, but none of this is necessary
in an Eclipse plug-in. You can save a lot of code!
cW
On 2013-03-01 15:02:41 +0000, Alfredo Motta said:
> I solved like this
> uml_resource_uri =
> With this code and running the application as an Eclipse application I
| Re: Load profile in Eclipse plugin project [message #1015723 is a reply to message #1015696] |
Fri, 01 March 2013 16:45  |
Kenn Hussey Messages: 1616 Registered: July 2009 |
Indeed, all these registrations are performed automatically through
plugin extensions when running within Eclipse.
Kenn
On 13-03-01 2:14 PM, Christian W. Damus wrote:
> Hi, Alfredo,
> I'm glad that it's working for you now, but none of this is necessary in
> cW
>> I solved like this
>> uml_resource_uri =
Current Time: Tue May 28 17:40:23 EDT 2013
Powered by FUDForum. Page generated in 0.01792 seconds
