| Custom PropertySheetPage based on selected EObject [message #1015636] |
Fri, 01 March 2013 08:47  |
Joris Lückenga Messages: 5 Registered: March 2013 |
Junior Member |
i´m working on an XML-Editor and the generated and modified Plugin works quite well.
Now i have truble implementing a customized PropertyView:
I tried to extend a class from ExtendedPropertySheet - so i could override the selectionlistener and trigger a change of the PropertySheetPage when a certain EObject is selected.
But this seems to be a dead end, since i can´t access the viewer of PropertySheetPage class to change the content (i just achieved to change the color...). I wanted to store the default propertyView and change it when the EObject (with name X and value Y) is selected.
Those "special" EObjects contain a Hex-Value and every Bit should be a checkbox instead of the complete value
When other Objects are selected the view should change to the default property-View.
What would be the best way to achieve this? i would be very glad to get help
Joris
[Updated on: Fri, 01 March 2013 09:25] Report message to a moderator
| Re: Custom PropertySheetPage based on selected EObject [message #1015919 is a reply to message #1015636] |
Mon, 04 March 2013 04:26  |
Ed Merks Messages: 24549 Registered: July 2009 |
Joris,
Comments below.
On 01/03/2013 2:50 PM, Joris Lückenga wrote:
> works quite well.
> change it when the EObject (with name X and Value Y) is selected.
> property-View.
> get help :)
I don't think that's achievable. It would seem better to try to achieve
a special cell editor that comes up for a hex value data type.
http://wiki.eclipse.org/EMF/Recipes#Recipe:_Create_your_own_property_editor_in_a_generated_application
> Cheers,
> Joris
FUDForum. Page generated in 0.11341 seconds
