Home » Eclipse Projects » Eclipse 4 » Reset perspective though command for perspective created by application model not showing any part i(Reset perspective though command for perspective created by application model not showing any part i)
Reset perspective though command for perspective created by application model not showing any part i [message #1015546] Fri, 01 March 2013 03:38 Go to next message
sumit singh is currently offline sumit singh
Member
Create RCP in eclipse juno .
Create a perspective using Application.e4xmi, add part stack and part.
And menu resetPerspective using org.eclipse.ui.window.resetPerspective command.
application runs perfect, but if you reset perspective then every think gone.
In JavaScript perspective in same RCP its work fine.
Application before reset.
index.php/fa/13624/0/
Application after Perspective
index.php/fa/13625/0/
Apllication.e4.xmi for above perspective
index.php/fa/13626/0/
Re: Reset perspective though command for perspective created by application model not showing any pa [message #1015580 is a reply to message #1015546] Fri, 01 March 2013 04:29 Go to previous message
Sopot Cela is currently offline Sopot Cela
Is this a e4 with compatibility layer app? Is there anything weird in the log ?
Previous Topic:Properties view (compatibility view)
Next Topic:Control over close button on Part tab
Current Time: Sat May 18 13:51:57 EDT 2013
Powered by FUDForum. Page generated in 0.01537 seconds
