| Validation after Transformation [message #1015549] |
Fri, 01 March 2013 03:48  |
Alex G Messages: 64 Registered: January 2012 |
Member |
Hi!
I have a text editor (XText) which creates a model A conforming to a meta model MA.
In order to validate A I have to transform the model A to a model B conforming to a meta model MB and validate B afterwards. If using Epsilon ETL and EVL, I will get EvlUnsatisfiedConstraint for the model B. The corresponding object which leads to the constraint violation is given by EvlUnsatisfiedConstraint.getInstance().
What I need is to show up errors in the text editor. Therefore I need to link somehow the objects from A which were needed in order to transform to some specific object B. Is this linking/mapping possible with Epsilon? This means, that I need some access to the meta model for the transformation.
Alex.
FUDForum. Page generated in 0.11167 seconds
