| Building Stardust [message #1015259] |
Wed, 27 February 2013 17:18  |
Oliver Kopp Messages: 7 Registered: March 2011 |
Junior Member |
I'm trying to follow the build instructions. However, I get following error:
[javac] /home/iaas3/stardust/engine/stardust-engine-base/target/src/org/eclipse/stardust/common/config/extensions/PojoExtensionsCache.java:88: compareAndSet(T,T) in java.util.concurrent.atomic.AtomicReference<T> cannot be applied to (<nulltype>,java.lang.Object)
[javac] sharedInstance.compareAndSet(null, instantiatePojoExtension(instanceType));
[javac] ^
What's going wrong? I tried both Win8 and Ubuntu 12.04.
What I want to try is the web-based BPMN modeller. Is there a more easy way to get that up and running isolated from the other components?
Oliver
| Re: Building Stardust [message #1015535 is a reply to message #1015436] |
Fri, 01 March 2013 02:39   |
Robert Emsbach Messages: 55 Registered: October 2011 Location: Shanghai |
Member |
Hi Oliver,
so far Stardust does not have an IRC channel. This would a good thing to have once there is sufficient demand. However, you are most welcome to connect with Stardust on Facebook and via this forum.
Obviously you have a good point with regards to the public updates to Java 6. In the customer base we had very little demand for Java 7 support so far, but I am sure that will change soon as Oracle increases the pressure. A move to Java 7 is needed and in planning but we are not there yet. As I hope you can also appreciate currently the participation in the Eclipse Kepler milestones and eventually in the release is our highest priority. For the time being please use Java 6 to build Stardust.
Best regards
Robert
[Updated on: Fri, 01 March 2013 02:40] Report message to a moderator
FUDForum. Page generated in 0.02235 seconds
