Home » Eclipse Projects » NatTable » Grouping AND Binding (GlazedLists)(does it work now? (combined with sorting and filtering))
Grouping AND Binding (GlazedLists) [message #1015294] Thu, 28 February 2013 01:21 Go to next message
Ludwig Moser is currently offline Ludwig Moser
hello!
i started a thread, like a year back in old sourceforge forums
http://sourceforge.net/projects/nattable/forums/forum/744992/topic/4936554
which asks the same question, but as the forum moved along i guess it got forgotten...
so to ask again. does grouping and binding work in the meantime (combined with sorting and filtering)
Re: Grouping AND Binding (GlazedLists) [message #1015305 is a reply to message #1015294] Thu, 28 February 2013 02:38 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk Fauth
you should have a look at the BlinkingGlazedListExample. I think this is what you are looking for. Smile
Greez,
Dirk
Re: Grouping AND Binding (GlazedLists) [message #1015361 is a reply to message #1015305] Thu, 28 February 2013 05:52 Go to previous messageGo to next message
NatTableExamples-0.9.0.jar\org\eclipse\nebula\widgets\nattable\examples\examples\_103_Events\BlinkingGlazedListExample.java
cant get the point. cant find Grouping and Binding in this example.
i tried to create a table, which can be sorted, filtered and grouped by items.
when i tried one year back, everything was possible but the grouping (as the grouping somehow did not work with the binding of glazed lists, if i remember right)
Re: Grouping AND Binding (GlazedLists) [message #1015365 is a reply to message #1015361] Thu, 28 February 2013 06:14 Go to previous messageGo to next message
Well, grouping is working with a TreeList in the back. I got sorting and filtering working with in trees. So it should be possible. But I never tried it with the grouping. Also I never used binding in that context. IMHO it should work, but I'm not sure why it is not working for you. Maybe it is just the wrong list reference you are passing into your layers/handlers. Try to consider always using the most specific list.
To do some more investigation on this we surely need some example code.
Re: Grouping AND Binding (GlazedLists) [message #1015372 is a reply to message #1015365] Thu, 28 February 2013 06:45 Go to previous message
i'll look at my table again (not sure if i can do it this week)
if i can't get it working, i'll leave a message here.
Previous Topic:Selection and focus
Next Topic:Collapsed group overlaps next group
Current Time: Thu May 23 09:24:21 EDT 2013
Powered by FUDForum. Page generated in 0.01602 seconds
