Home » Eclipse Projects » Eclipse 4 » Kepler M5 editor focus issue
Kepler M5 editor focus issue [message #1015321] Thu, 28 February 2013 03:41 Go to next message
Dirk Fauth is currently offline Dirk Fauth
I'm working with Kepler M5 and can see that it is working well, of course not perfect as it is a milestone release, but good enough to switch from Juno. Wink
When working with several open editors, it sometimes happens that the focus for key events stays in a different editor than the current active one. A quite annoying bug.
It is hard to reproduce the bug. I also didn't find a corresponding bug in bugzilla (but maybe my searching skills need to be improved Wink )
So before I create a ticket, is this behaviour already known?
Greez,
Dirk
Re: Kepler M5 editor focus issue [message #1015340 is a reply to message #1015321] Thu, 28 February 2013 04:39 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
Sounds similar to https://bugs.eclipse.org/bugs/show_bug.cgi?id=401835
Tom
Am 28.02.13 09:41, schrieb Dirk Fauth:
> switch from Juno. ;)
> in bugzilla (but maybe my searching skills need to be improved ;) )
> Greez,
> Dirk
Re: Kepler M5 editor focus issue [message #1015348 is a reply to message #1015340] Thu, 28 February 2013 05:03 Go to previous message
yes, that sounds like the same bug. I added a comment with some additional key bindings that have that behaviour
Previous Topic:RCP Toolbar/Menu issues using the Compatibility Layer after migrating to 4.2
Next Topic:running a product, swt plugin not found, latest e4 SDK I build
Current Time: Mon May 20 04:46:03 EDT 2013
Powered by FUDForum. Page generated in 0.01538 seconds
